Engine bay colour?
Old May 25, 2008 | 03:47 PM
corvettedave383's Avatar
corvettedave383
Default Engine bay colour?
what colour should the engine bay be on a 78 vette??
cheers
dave
Old May 25, 2008 | 03:51 PM
Kellys~hotrods's Avatar
Kellys~hotrods
I took a look in one of my books, looks like it's semi-gloss black. I don't have a color code for it though.
Kelly
Old May 25, 2008 | 06:31 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Kelly
Just finished painting my firewall with semi-gloss black engine enamel. Looks !!!
Old May 25, 2008 | 09:06 PM
72LS1Vette's Avatar
72LS1Vette
Here are a few pics of Krylon Semi-gloss Black. Don't know if it's NCRS correct but I like it.
Rick B.
Old May 25, 2008 | 09:29 PM
rponfick's Avatar
rponfick
I am using Krylon Semi Flat Black, number 1613. It is the closest to stock I have found.
Ralph.
Old May 25, 2008 | 10:54 PM
Kellys~hotrods
If you know someone that could get you the color code for that paint (a friend that works at a body shop?), you could go to your local paint supplier (automotive) and they can sell you the correct color in a spray can for a fee. That way you could paint it knowing you have the correct color if you want to go that route.
Old May 25, 2008 | 10:55 PM
Carl Granquist's Avatar
Carl Granquist
Default black
Ralph.
Is this true for the underside of the hood also? I have some touch-up to tend to there.
Old May 26, 2008 | 07:46 AM
jimweis's Avatar
jimweis
No code. It's black with a flattener. Krylon semi-flat in the spray can is the closest to the correct sheen, requires at least 3 wet coats. Black is black when it comes to color you need to have the body shop match the sheen of the Krylon, this can only br done trial and error.
Old May 26, 2008 | 08:46 AM
78Vette-SA's Avatar
78Vette-SA
I use SEM Trim Black (which is very close to the Krylon) and can be bought in Qt. cans for spray. I've actually touched each other up with one or the other and they match perfectly.
To Engine bay colour?
