Misc. Rookie Questions
I have some questions to non-related various things. Any help is appreciated!1. First off, I want to buy a torque wrench (clicking type) and am wondering what the best range is (20-100, 30-200, etc.) for most, if not all, torqueing needs.
2. I think I read somewhere that there are supposed to be rubber flaps behind the front grilles. Is this true or am I imagining it?
3. My left speaker is "popping" half the time. Is there an easy way to diagnose this without having to take the whole dash off?
4. When I open the driver side door, the buzzer goes off, but not when I open the passenger door. Is that how it's supposed to be? Also, none of the interior lights come on when either door is open, although they come on when I turn the light switch to the left (past the brightest setting).
5. I have an automatic transmission. Is there supposed to be a light or orange strip next to the gear shifter to indicate whether it's in P, R, N, 3, etc? Or is this just done by feeling?
6. The A/C currently isn't working. Nothing is even blowing. But the previous owner gave me the old blower relay and a new one. They're almost identical, but not quite. The question I have is, does anyone have a picture showing where this mounts and which wire goes to which terminal? (The three wire connector is broken off)
7. What is the function of the front lower valence? The second picture of it shows that two of the bolt holes are stripped off. What would you suggest I do? Try to do some work on this one, or buy a new one? Would I have to paint it, or would it not be noticeable? Also, does this have to be installed for the front spoiler to be installed?
8. I found this rubber piece in one of the rear compartments... what the heck is it!?
9. Last question: This looks somewhat unsightly when I take the t-tops off... any suggestions on how to clean this up?
Thanks for any help you can give!!!
You're going to need 1 that goes at least to 100 ft-lbs for a few things, and you'll probably also want a 1/4" drive one for the torquing smaller things. sometimes there just isn't room for a big torque wrench. I use the bigger 1 way more often though.
As far as I know the rubber flaps were only used on the cars with the chrome front bumpers. with the rubber bumpers the lights are a little more protected by the grilles
someone else might have some ideas on this one, but you'll have to get in there eventually to really figure out what the problem is.
the key warning buzzer is only tied to the drivers door, but it shouldn't be going off without the key in the ignition. if you take off the kickpanels you can check the wiring for the door switches, sounds like at least part of the problem
No indicator in early years. I know 73 didn't have one, but I can't tell you when they added it.
I think it's main function is for mounting the front spoiler, but it cleans up the bottom of the front end too.
Looks like the cover for the spare tire lock.
Does the lower valence bolt on, and then the spoiler after that? Or do the same bolts go through both, so the valence acts as just a middleman?
Also, I have acquired a wiring diagram, but it doesn't help me see which of the three wires goes to which terminal on the blower motor relay. The diagram shows the black going to the lone terminal, and the orange/purple/dark blue going to the three. Does anyone know which ones goes to which?
Thanks again!
That being said, buy a 0-150 (or so) inch-pound wrench and a 0-120 (or so) foot-pound wrench. That will do almost anything you will encounter.
As far as the radio 'popping' goes.... when do you hear the popping? And is it a single pop or several all at once, or continually? If it is an occasional single pop, and occurs when you exercise an electrical switch (brake light, fan, etc.), the problem is that the [noise] filter capacitor on that circuit has been removed or gone bad. Check your AIM and you can find the locations for those capacitors. If you can associate the popping with some accessory, you can isolate which filter you need to fix. If it is some other kind of popping noise, try to give more detail and we'll see what other advice might help.
Sears is good ....Snap on is better. buy good now so you don't have to pay again later. Also always take it back to zero before putting it away.
Only "flap" I can think of is the hood flapper on the hood air system. (also runs in sync with the 400 auto kickdown)
When I open the driver side door, the buzzer goes off, but not when I open the passenger door. Is that how it's supposed to be? Also, none of the interior lights come on when either door is open, although they come on when I turn the light switch to the left (past the brightest setting). You've got some wiring issues. Nothing to keep you from enjoying the car for the moment,,, but buy an electrical diagram (E-BAY) and start reading. Then when you have some free time take it apart and have a look. Probably is something simple but could be a "bubba" in there. Good thing about the car is its easy to work on.
I have an automatic transmission. Is there supposed to be a light or orange strip next to the gear shifter to indicate whether it's in P, R, N, 3, etc? Or is this just done by feeling? Right there with ya wondering why ......it'll all work out though. Drink more cold beer and it won't seem so important after a while.
Other topic: I don't really care if there's an auto shift indicator, but if there originally was one and it wasn't too hard to fix, I'd like to do it. Sounds like it wasn't there in '74 though. Cold beer solves a lot of problems, doesn't it?
Removing the speakers themselves requires a small 1/4 drive socket and a lot of patience on the ones closest to the windshield. I simply replaced mine with speakers from WalMart. I believe they were 3x5 and they have worked great. No more noise. Also replaced rears. They are all hidden and unless you are going for Bloomington Gold, no one will know. I though dropped in a Sony CD and enjoy great sound.
Hope this helps.
