waterpump belt?
Old May 26, 2008 | 08:46 PM
rebc3's Avatar
rebc3
Default waterpump belt?
ive noticed in a couple photos that some people have a small belt running behind the powersteering pump belt that just goes around the crank pulley and the waterpump pulley. is this nessecary? i am only running the belt around the PS. do i need this small single belt?
Old May 26, 2008 | 09:19 PM
ochsy's Avatar
ochsy
My 74 has 3. From the front they are AC, Crank-alt-waterpump, and finally a small one crank to power steering only.
Old May 26, 2008 | 09:24 PM
Ray Y's Avatar
Ray Y
It will work without it, however you run the risk of losing your main engine cooling life support if you lose the one belt you currently have.
Old May 26, 2008 | 09:26 PM
hwcoop's Avatar
hwcoop
mine has no ps or ac. If the alternator belt broke you could still drive the car to the shop with the small water pump belt keeping the motor cool, another Corvette feature
unlike the griswald family wagon where the motor would be cooking too if the alt belt went
Old May 26, 2008 | 09:28 PM
rebc3's Avatar
rebc3
is this a vette belt? what do i ask for?
Old May 28, 2008 | 05:38 PM
rebc3's Avatar
rebc3
Old May 28, 2008 | 05:58 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
You should be able to get the belt from most any parts place if the counter person is any good. I put that belt on mine to help reduce squealing of the water pump pulley at higher RPMs. I think it was 36 inches long. A bear to get on though, but well worth it.
Old May 28, 2008 | 10:53 PM
67-73-76's Avatar
67-73-76
I just went through thid on a 77 L-82 4 speed car with air conditioning.
I had the motor rebuilt and wanted to get the car running without the AC compressor.
So without the compressor belt, the only belt turning the water pump was the alternator belt and I wanted 2 belts turning the water pump.
I bought the short crank/water pump belt for cars without AC and tried installing it but it was too short.
I went back and forth to NAPA trying several belts but could not find one to fit.
I researched the part numbers in AIM and discovered that cars without AC came with a different water pump pulley and a different crankshaft pulley. The pulleys are differnt diameters than the pulleys for cars with AC.
I bought the correct non AC pulleys from Corvette Central, mounted them, and then the short belt I orignally bought fit right up.
Old May 29, 2008 | 11:45 AM
rebc3's Avatar
rebc3
im gonna try to find one
Old May 29, 2008 | 02:09 PM
Jay-Dog's Avatar
Jay-Dog
Why bother. I loaned my car to the inlaws last weekend for a cruise event. Somehow, the alt belt broke which in turn also threw the a/c and p/s belts. They drove the car another 40 miles to my house with no problems. Put three new belts on two days ago. Besides, how would you tension that belt since both pulleys are in fixed positions?
Old May 29, 2008 | 05:03 PM
eastltd's Avatar
eastltd
The correct belt is sized for the fixed pulley distance and does not have to be tensioned. You do have to remove one pulley to install the belt though.
To waterpump belt?
