Timing light and multispark CD ignition ?
Old May 26, 2008 | 09:29 PM
Mr. Beam's Avatar
Mr. Beam
Default Timing light and multispark CD ignition ?
Hi,
Any reasons to suspect a false/unstable reading with a timing light on a multispark CD ignition system?
/ Mr. Beam
Old May 27, 2008 | 09:41 AM
Amelio's Avatar
Amelio
What ignition system are you using?
Old May 27, 2008 | 10:05 AM
stingr69's Avatar
stingr69
MSD ignition will cause problems with many brands of timing lights.
-Mark.
Old May 27, 2008 | 10:28 AM
Mr. Beam's Avatar
Mr. Beam
I'm using a Mallory Hyfire 6AL. Have problems confirming 36 deg total @ 2800 rpm. It bounces back and forth between 32-40 deg with my dial back timing light from Craftsman.
And yes, I have checked the distributor gear end play - it's OK.
Do I need to bypass the ignition box to set the timing?
Kind of defeats the purpose...
Any insight in this is appreciated.
/ Mr. Beam
Old May 27, 2008 | 11:58 AM
73StreetRace's Avatar
73StreetRace
I also had a few problems with my timing light and my MSD 6A electronic ignition : the index on the harmonic balancer was always moving by a few degrees, making the reading impossible.
I finally tried this with success : Instead of using the car battery to supply the timing light, I used an external battery ( An external 12V power supply could also be used ) to supply energy to my timing light.
I only used the #1 cylinder ignition wire to give a proper signal to the light and it worked great !
It seems that the CD electronic ignitions create some small perturbations on the electrical systems of the car, and they are sometimes detected as a false signal by the timing lights.
Using a separate supply addresses this issue
Old May 27, 2008 | 09:45 PM
bozzman3's Avatar
bozzman3
I think the incorrect readings are caused by the multiple sparks that the box puts out per combustion cycle.I am surprised that a separate power source would make the readings correct.I have been told that a electronic dial back timing light will not work but a plain standard light will.
Old May 28, 2008 | 01:17 AM
Kellys~hotrods's Avatar
Kellys~hotrods
I have a dial back timing light and have used it with MSD box/distributor. It worked fine for me I believe the light is a craftsman.
Old May 28, 2008 | 01:20 AM
73StreetRace
The timing light will light at the first discharge of the CD ignition box and the timing light needs some time to reload. Generally, the CD ignition boxes like MSD make multiple sparks in about 2 or 3 crankshaft degrees, no more. I don't think that any timing light can detect and reload so fast, so you will just see the first spark and not the following ones because they are too close from the first.
All what I can say is that the external supply worked for me, and that it doesn't cost much to try
Old May 28, 2008 | 05:37 AM
corvette744's Avatar
corvette744
Try another timing light-it shouldnt be bouncing at all.I have seen faulty balancers and plug wires do this.Is the light steady all the way to 2500rpm or does it cut off and on.If its cutting off try a spare #1 wire and recheck.
Old May 28, 2008 | 08:23 AM
69ttop502's Avatar
69ttop502
I would think setting total timing at 3000 or so rpm would be fine as by then the MSD is only throwing one big spark. It works OK with my box. I get a little jumping at lower rpms.
Old May 28, 2008 | 09:18 AM
Mr. Beam's Avatar
Mr. Beam
Thanks, a couple of good ideas to try here.
I will try to get hold on another timing light and then also rev it up to ~3500 and see if it stops jumping around. That would shut down the multi spark feature and I still would see 36 deg total if everything is set up right.
BTW. Plugs, wires and balancer - all brand new.
/ Mr. Beam
To Timing light and multispark CD ignition ?
