sidepipe installation
Old May 29, 2008 | 11:59 AM
fitter's Avatar
fitter
Default sidepipe installation
has anyone installed the hoker headers and sidepipes on an '82 crossfire? i'm considering installing them on my '82 crossfire, but don't know how to install them with no provisions for the AIR pump and o2 sensor. any help would be appreciated!
Old May 29, 2008 | 01:10 PM
blckslvr79's Avatar
blckslvr79
They're not emmission legal, so your AIR pump would need to be removed...If legal in your state.
As for an 02 sensor, you can buy the weld in bung from Summit or Jegs and weld it into one of the collectors.
Old May 29, 2008 | 01:32 PM
Kellys~hotrods's Avatar
Kellys~hotrods
Having done this before cleans up that engine bay as well.
Kelly
Old May 29, 2008 | 01:49 PM
82crossfirevette's Avatar
82crossfirevette
I'm considering the same thing.
You may be done with inspection if the car is registered as a Classic/Historic vehicle. Check your state Classic Vehicle laws.
Kellys~hotrods: Did you keep it or reverse back to stock? Will removing the air pump mess with the air flow to the fuel injectors?
Old May 29, 2008 | 04:43 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Some states don't do emissions inspections on older vehicles. Missouri has gotten to the point where if there isn't an OBDII port, they don't bother. On an '82 with the Cross-Fire system intact, a bung for the O2 sensor will have to be welded onto one collector, other than that things should be pretty straightforward.
To sidepipe installation
