FronT suspension
Old May 29, 2008 | 01:57 PM
Black76's Avatar
Black76
Default FronT suspension
I have the engine out of my 76 for a rebuild its a 454 big block . With the engine out i took the time to remove the upper and lower control arms and coil springs for replacement . with everything out im replacing the old power steering setup with a new steeriods rack and pinion setup. The question i have is weather or not to use new coil springs or replace the coil springs with a new upfront composit spring ?
Old May 29, 2008 | 02:01 PM
Durango_Boy's Avatar
Durango_Boy
Unless you're planning track time or auto crossing, the stock springs should work fine.
Old May 29, 2008 | 02:36 PM
68/70Vette's Avatar
68/70Vette
I think that the front composite spring set-up will reduce road clearance between the two front wheels.
To FronT suspension
