cig lighter
Old May 29, 2008 | 12:05 PM
chemo's Avatar
chemo
Cruising
Default cig lighter
i have a 75 vett and i was wondering if any body had a picture of the cig lighter all wired up or a diagram
thanks guys
Old May 29, 2008 | 12:08 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
75 assembly instruction manual (AIM) will help. There is one hot wire to the element and possibly a ground wire to the case. It might have a clip-on illumination lamp for the side of the case.
Old May 29, 2008 | 03:28 PM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
Yup, little clip on wiring harness goes to the bottom lug of the lighter. Little springy metal housing around one of the dash light type bulbs (1 gray wire) fits into the side of the housing of the lighter. Grounds thru the console. Make sure the console housing is grounded. Basically, this bulb housing grounded to this, grounded to this, grounded to this, grounded to this, grounded to that. Long chain of grounding: check it.
To cig lighter
