Hazards Dont Work, Help!
Old May 29, 2008 | 03:53 PM
1980 c3 man's Avatar
1980 c3 man
Navigator
Default Hazards Dont Work, Help!
If your bulbs are good, and you already replaced the switch in the fuse box and you crawled under the dash to check the turn signal connection, and its good. Your turn signals work fine. Whats left? How do you trace it?
Old May 29, 2008 | 04:41 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Flasher on the fuse box?
Old May 29, 2008 | 06:18 PM
Durango_Boy's Avatar
Durango_Boy
Replace the hazard flasher located on your fuse panel.
Old May 29, 2008 | 08:17 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
there is also a fuse (regular... like a 20a) in the fuse panel, along with the round hazard blinker. i cant member which, but it takes 3 minutes to check em all
To Hazards Dont Work, Help!
