Going Back To R12?
Old May 30, 2008 | 08:59 AM
CCrane65's Avatar
CCrane65
Default Going Back To R12?
Ok, I've seen several threads on converting to R134 but what about the other direction?
My system was previously converted to R134 and holds the charge fine it just isn't cold. It's cool but not sufficient.
Do all the same parts have to be replaced to go backwards or can I evacuate the system and refill with R12 and R12 oil?
cc
Old May 30, 2008 | 09:04 AM
tommyleea's Avatar
tommyleea
I am not sure if you can get R12 anymore, and if you can it is probably cost prohibitive. Cheers.
Tommy
Old May 30, 2008 | 09:15 AM
wnmech's Avatar
wnmech
In my opinion if you flush out your system and replace the receiver dryer and service the system with the proper oil you should be fine. R-12 is still available you will need to find someone with the certification to purchase it for you. Last year I was purchasing the small cans for A little over $30 dollars a can. If you do a Ebay search for R-12 you will find a lot of it for sale for a pretty reasonable price.
Old May 30, 2008 | 09:19 AM
CCrane65's Avatar
CCrane65
Tommy
There's quite a bit of it for sale on that auction site but you have to either certify that you are going to resell it to an EPA 609 certified technician or provide your certification number if it is for yourself.
I will simply tell them it's for resale then give it to my mechanic to install. There's nothing that says I have to get money for the resale.
It seems to run anywhere from $15 to $25 per 14 ounce can.
cc
Old May 30, 2008 | 09:27 AM
stingr69's Avatar
stingr69
I bought a case at about $20 a can. That should last me a long while as long as the rest of the system holds out. I would say that getting parts may be more problematic than getting refrigerant in the future.
JMO.
-Mark.
Old May 30, 2008 | 11:10 AM
Wrecked82's Avatar
Wrecked82
Tommy
I replaced my 25 year old system with another R12 last summer. Availability of R12 wasn't a problem. Car hasn't been this cool for years!
Old May 30, 2008 | 11:37 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
This is one of the reasons R12 is still in demand, I believe, as it does a much better job of cooling than 134a in cars that were designed for it.
Old May 30, 2008 | 12:37 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Tommy
Drive to your local O'Reilly with a 609 certificate. You will leave with brandy-new R12.
True...if the system wasn't re-tuned for R134a. Slapping one of those Hell-Mart conversion kits on does not a proper conversion make, and cooling will suffer.
Old May 30, 2008 | 01:54 PM
yellow-fever's Avatar
yellow-fever
I also converted my 74's system BACK to R-12.
Old May 30, 2008 | 02:11 PM
CCrane65's Avatar
CCrane65
Did you replace your receiver/drier?
cc
Old May 30, 2008 | 02:42 PM
Jud Chapin's Avatar
Jud Chapin
cc
The dryer should be replaced every time the system is opened.
To Going Back To R12?
