Engine build problem
Old May 30, 2008 | 05:15 PM
hgm's Avatar
hgm
Default Engine build problem
Plans are made, all parts are here and I am going to put my new 383 together this weekend. been collecting parts for to long. Pulled the bag off of the block and I have Rust! Not pits, but small brown spots on the cylinder walls and on the deck. I am looking for suggestions. Should I just clean and assemble? I tried to clean with a spray lube. The spots lighten but don't go away. Should I have the block re-honed? I know I am going to get asked why I let this happen. I thought the block was coated heavy enough. The machine work was done a couple of years ago and the block was still perfect 4 weeks ago.
Old May 30, 2008 | 06:06 PM
gkull's Avatar
gkull
I'd just clean and assemble
Old May 30, 2008 | 06:24 PM
Oldguard 7's Avatar
Oldguard 7
What gkull said. If you feel uncomfortable with the rust spots in the cylinders, remove with crocus cloth or a green pad with warm soapy water.
Old May 30, 2008 | 07:19 PM
Gordonm's Avatar
Gordonm
Should be fine. Clean the cylinder walls with automatic trans fluid. Keep going until the rag comes out clean. Tranny fluid is designed to keep dirt suspended so it will take it off the walls and leave you with a clean cylinder wall. It is amazing how much junk is left on the walls after machining.
Old May 30, 2008 | 07:38 PM
gkull's Avatar
gkull
I've soap and water cleaned a block before starting to asseble and it gets spot rust before the whole block is dry.
Old May 30, 2008 | 08:05 PM
TimAT's Avatar
TimAT
Unless there's pits, it's no problem. Wash the block with HOT soapy water, rinse the poo out of it, wipe it with ATF, and build it..
To Engine build problem
