turbo 400 shifting problem
Old Jun 3, 2008 | 10:32 AM
TFitz's Avatar
TFitz
Default turbo 400 shifting problem
my 70 turbo 400 has been wanting to go into passing gear at the slightest bit of acceleration while cruising along. I messed with the linkage bracket on the carb. does the position of this bracket make a difference for when the trans wants to shift to passing gear,or is it something else going on. Had trans completly rebuilt last year and has been shifting ok till now.thanks in advance.Tom
Old Jun 3, 2008 | 10:38 AM
V-Twin's Avatar
V-Twin
The kickdown switch is located on your throttle pedal bracket, adjust the switch
