courtesy lights help
Old Jun 3, 2008 | 07:21 PM
cargo247's Avatar
cargo247
Default courtesy lights help
81
the courtesy lights work if i turn them on though the light switch but not the door switches???? is the timer done ???if it is, is there a way to bypass the timer?? so the lights come on when you open the door and off when you close it.. basic.. no timer. i thought it could be a bad ground but if it was the lights would not work through the head light switch. 85 bucks for a timer not!!
as well the horns are not working could the horn relay be done (new horns) its not the fuse as the horns work though the courtesy light fuse.
any help would be great
Todd
Old Jun 3, 2008 | 07:29 PM
SIXFOOTER's Avatar
SIXFOOTER
The door switches provide a ground to the light circuit, thru the timer. If the timer is dead or the switches have lost their ground the doors will not operate the lights.
Old Jun 3, 2008 | 07:36 PM
cargo247's Avatar
cargo247
got it thanks i have this drawing, but can i bypass the timer ??? has anyone done this? an if so how??
Todd
Old Jun 3, 2008 | 07:47 PM
SIXFOOTER's Avatar
SIXFOOTER
just unplug the timer and jump the 2 white wires together
Old Jun 3, 2008 | 09:26 PM
cargo247's Avatar
cargo247
thank you sir
To courtesy lights help
