Warning buzzer won't stop.
Old Jun 1, 2008 | 09:56 PM
Bigbrett78's Avatar
Bigbrett78
Navigator
Default Warning buzzer won't stop.
My warning buzzer will not stop when the headlights are on. How do I disconnect it? Thanks for any advice.
Old Jun 1, 2008 | 10:01 PM
terry82's Avatar
terry82
that can be fixed disconnect the buzzer.sorry i cant be of more help
Old Jun 1, 2008 | 11:39 PM
...Roger...'s Avatar
...Roger...
Check your 10 amp "Gauges" fuse.
Old Jun 1, 2008 | 11:51 PM
wattac2's Avatar
wattac2
Default Disconnect the Limit SW at the headlights
Either fix/adjust/disconnect the limit switches at each headlight. You'll have to reach up from under the nose of the car to get to the switches/connectors.
Andy
Old Jun 1, 2008 | 11:55 PM
...Roger...
Andy
I think he's working on a 78
Old Jun 2, 2008 | 07:42 PM
Bigbrett78's Avatar
Bigbrett78
Navigator
Sorry about that, it a 78 L-82, 4 speed. It went off and on a few times, but then stayed on the rest of the night. I'll check that fuse right now.
Old Jun 2, 2008 | 07:49 PM
Bigbrett78's Avatar
Bigbrett78
Navigator
Fuse looks fine, and the gauges still work.
Old Jun 2, 2008 | 07:55 PM
Bigbrett78's Avatar
Bigbrett78
Navigator
And I just looked around the vacuum cans for the headlights, but couldn't find any electrical components.
Old Jun 3, 2008 | 01:05 PM
wattac2's Avatar
wattac2
Default '78 May Not Have Limit SW's
My suggestion concerning the limit sw assumed '78's were the same as ''69-70dish's. Not sure if that's true.
Andy
Old Jun 3, 2008 | 04:21 PM
bmotojoe's Avatar
bmotojoe
1977-1978 used this style of buzzer,
At your fuse block might be a black box about 2.5”x2.5”. It plugs into the main fuse box and is held in by a plastic clip on one side. There should be a gray wire leaving it with a green plastic connector on the end. Unplug the wire at the steering column and unplug the buzzer from the fuse block. I have seen a couple of styles of buzzers but typically this is what to look for.
Old Jun 3, 2008 | 09:35 PM
Bigbrett78's Avatar
Bigbrett78
Navigator
Oh, thanks a million! I immediately saw the box on the side of the fuse box. Popped it off, stuck it back on. No more problem. It had apparently just vibrated loose. This forum is awesome!!
To Warning buzzer won't stop.
