Maybe look into it. I think they even have a slightly more aggressive one than that too.
Running that cam with some zz4 heads, although not a race cam by any stretch of the imagination, it does make good mid-range power. Runs out of gas (no pun intended) at @ 5000. It is a good match for a cast crank and pistons (which I currently have) where you do not want high rpm's. if you want a touch more power they make a 224/224 grind also
I actually had two of them when Professional Products started making intakes. I had one on a 350, though it as not a Vortec, it flowed greet. I have also used them a lot on Mopar engines, and there is nothing wrong with them. The Vortec version again, is just a copy of the Edelbrock version. Edelbrock is made in America, but PP intakes are cheaper. Nothing wrong with using them if you're on a budget.
That ebay add does not spacify if it's a pro-products intake. Is it? I guess that only so many companys are making them so perhaps it is?
thakns
timg
