fast burn 350
Old Jun 4, 2008 | 01:10 PM
chemo's Avatar
chemo
Cruising
Default fast burn 350
hey guys has anyone put a fastburn 350 in there vette
i have a 75 and was wondering if it would drop right on in
and if the bell housing needed to be changed
thanks
Old Jun 4, 2008 | 01:39 PM
SpE3dF0x's Avatar
SpE3dF0x
GREAT QUESTION, I was thinking about doing a VORTEC change on my 355??? Anyone have any ideas what is needed for the conversion? PLEASE!!!!!!!!!!
Old Jun 4, 2008 | 02:37 PM
Durango_Boy's Avatar
Durango_Boy
Here, check this out.
http://photos.imageevent.com/durango...tec%20Swap.pdf
Old Jun 4, 2008 | 02:53 PM
Saint's Shark's Avatar
Saint's Shark
Durango Boy, how much horsepower do you estimate can be gained going with the swap you outlined? First let me tell you what I currently have - L-82 (auto) with smog equipment still attached, stock intake manifold and exhaust mainfolds, stock Y-pipe exhaust w/ the "pancake" cat no less! Unfortunately, funds aren't falling out of the trees these days, but I do plan on getting headers (type to be determined - maybe some McJacks) and an Allens chambered exhaust system. I will be removing the smog crap as well.
Old Jun 4, 2008 | 03:00 PM
Durango_Boy
While I don't know your stock HP numbers, if you can do the Vortec swap, AND install headers and 2.5" exhaust with some good mufflers, you're looking at right around 300 HP at the wheels...based on a forum member that did the Vortec swap to his L82. You'll have a rough new compression ratio of about 9.5:1. The whole swap, without touching the bottom could cost around $500 - $600 if you find good deals on the heads. If you do a bottom end rebuild and bore the block, you can add another $600.
That doesn't include the exhaust.
Old Jun 4, 2008 | 03:04 PM
Saint's Shark
I apologize for the hijack....
BTW - thanks DB
Old Jun 5, 2008 | 12:09 AM
dstaley's Avatar
dstaley
I haven't been on the forum in years, and back then only to get a new rear cap since mine has decomposed. This is my first post in a loooooong time!
I'm planning a vortec swap on my '76 L48 soon. My plans are to use the stock carburetor, exhaust manifolds (the exhaust has been replaced with 2-1/2" tubes and magnaflow muffs years ago). The engine is unmodified now, with 56,000 miles so I'm going to roll the dice and leave the bottom end alone except for a new oil pump, rear main seal, and one-piece gasket. Other thoughts:
          So far my parts list is around $1000 after paying $175 for the heads plus having them cleaned up & magged. I'm not sure what valves & guides they may need.
          Will the Edelbrock intake really fit? That would shave $100 off of the budget, which is a welcome change.
          Any other thoughts/suggestions/rebukes?
          Old Jun 5, 2008 | 08:18 AM
          timgman's Avatar
          timgman
          Default It appears that you'll need a drop air filter
          It appears that you'll need a drop air filter to run these intakes.
          I plan on getting the 89$ cheapo from ebay and I'll keep you posted,,,
          timg
          Old Jun 5, 2008 | 08:38 AM
          gingerbreadman1977's Avatar
          gingerbreadman1977
          my half finished ( now finished ) Vortec 350 with Gm fast burns, air gap , demon 750. crane roller cam in my gf,s dining room.
          Old Jun 5, 2008 | 09:33 AM
          Durango_Boy
          Originally Posted by dstaley
          XE268 camshaft, matching lifters
          This is a very popular cam and lifter combo for the Vortec swap. Seems to make great power, and at a good low price.
          http://store.summitracing.com/partde...3&autoview=sku
          Maybe look into it. I think they even have a slightly more aggressive one than that too.
          Old Jun 6, 2008 | 03:45 PM
          timgman's Avatar
          timgman
          Default Brackets...
          How about the brackets fitting... alternator PS pump...?
          will these line-up with the vortec intake?
          thanks
          timg
          Old Jun 6, 2008 | 04:24 PM
          Durango_Boy
          thanks
          timg
          Yep, all the accessory holes on the Vortec heads are the same as your stock heads. The Vortec intake might pose some mounting issues but they make them to mimic the stock intake only using a different bolt pattern.
          Old Jun 6, 2008 | 04:34 PM
          SpE3dF0x's Avatar
          SpE3dF0x
          Can you use the stock one I have on witout center bolts?
          Old Jun 6, 2008 | 04:39 PM
          Durango_Boy
          If you have anything that bolts to the valve cover bolts then no, because the Vortec heads are all center bolt unless it's an after market casting that uses a perimeter bolt pattern.
          Old Jun 7, 2008 | 06:46 AM
          timgman's Avatar
          timgman
          Default 89$ vortec intake onebay garbage?
          Is the 89$ intake on ebay garbage? Anyone ever used it that you are aware?
          Old Jun 7, 2008 | 09:23 AM
          Durango_Boy
          Which one? Link it. I have used Profession Products intakes, which are Edelbrock imitations, and they work great. Yes, they are Chinese made and cheaper, but they are based on a proven design and give or take some cheaper casting clean up, they flow very well.
          Old Jun 7, 2008 | 12:07 PM
          timgman's Avatar
          timgman
          http://cgi.ebay.com/ebaymotors/NEW-S...spagenameZWDVW
          To fast burn 350
          Old Jun 7, 2008 | 06:55 PM
          Durango_Boy
          Yep, that'll work great.
          Old Jun 8, 2008 | 06:35 AM
          timgman's Avatar
          timgman
          Is this essentially a edelbrock vortec performer copy? ? has anyone else used it?
          Old Jun 8, 2008 | 09:00 AM
          Durango_Boy
          I actually had two of them when Professional Products started making intakes. I had one on a 350, though it as not a Vortec, it flowed greet. I have also used them a lot on Mopar engines, and there is nothing wrong with them. The Vortec version again, is just a copy of the Edelbrock version. Edelbrock is made in America, but PP intakes are cheaper. Nothing wrong with using them if you're on a budget.
