Power steering ram problem
Old Jun 4, 2008 | 07:27 PM
skipinhouston's Avatar
skipinhouston
Default Power steering ram problem
Guys.
I can't get the ram apart.
The retaining clip is out of the cylinder boss, there doesn't seem to be anything else in the way, but the piston won't come out out of the cylinder bore. It just clunks solid as a rock and will not come out of the bore.
I've never had one do this before.
What am I missing?
Anyone got any suggestions? I need to put new seals in it.
Thanks,
Skip in Houston
Old Jun 4, 2008 | 07:58 PM
A88FXRS's Avatar
A88FXRS
that is a welded cylinder and will not open. i have cut a few open in a lathe then re-welded rod end back on. good luck
Old Jun 4, 2008 | 08:49 PM
wombvette's Avatar
wombvette
Yep, has to be cut apart. Easier to just buy one done.
Old Jun 5, 2008 | 07:24 PM
skipinhouston
Come on guys.
I bought a rebuild kit and the parts manual says it comes apart.
Why would the vendors sell the seal kit to rebuild it if you have to cut things apart.
I'm missing something.
Skip
Old Jun 5, 2008 | 08:11 PM
A88FXRS's Avatar
A88FXRS
We Gave You The Straight Scoop !! The Rod Seal Can Be Replaced Externally But Cylinder Packings Are Closed In
Old Jun 5, 2008 | 08:23 PM
Paul L's Avatar
Paul L
Originally Posted by skipinhouston
Come on guys.
Skip
I bought the re-build kit as well. Something is not being said here. Can they be re-built or not? If not why are kits sold by Corvette vendors without weld/non-amateur caveats/warnings? Most of us do not have a torch or expertise beyond basic seal replacement in such a critical steering component.
Old Jun 5, 2008 | 08:36 PM
A88FXRS's Avatar
A88FXRS
THEY CAN BE REBUILT, BUT IT REQUIRES A MACHINING OPERATION TO OPEN UP AND WELDING TO CLOSE. I HAVE DONE 4 OR 5 THIS WAY. INTERNAL SEALS AND WIPERS ARE COMMON HYDRAULIC COMPONENTS. POSSIBLY ONE REASON IS THE LIABILITY ISSUE. THAT SYSTEM CAN RUN APPROX 1,000 PSI. IF A SCREW ON HEAD EVER CAME LOOSE, ALL HELL COULD BREAK LOOSE ON THE HIGHWAY.
Old Jun 5, 2008 | 10:28 PM
Jim Shea's Avatar
Jim Shea
The kit that you purchased will fix the type of leak that drips on the floor (the piston rod seal.) The piston seal inside the cylinder will only seep from the side of high pressure back to the low pressure side. All leakage is internal. The power steering pump just has to work a little harder to supply more flow.
Jim
Old Jun 6, 2008 | 06:41 AM
Paul L's Avatar
Paul L
Jim
I have kits for the control valve and the ram but can't isolate the minor leak. This may be a clue: the leak occurs after a drive and when the car is parked. So the PS system is not under pressure at that point.
To Power steering ram problem
