need help with installing clutch disc
Old Jun 6, 2008 | 01:23 AM
madvette74's Avatar
madvette74
Default need help with installing clutch disc
hell..
it's been awhile, last year I had my motor built, and I am getting ready
to install it, except I cant remember what side faces the flywheel..
can you tell me by these picutres what side faces the clutch. it's a centerforce...
also can you tell me the tq amount for the pressure plate and flywheel?
do I need you use locktight on the bolts?
[IMG][/IMG]
[IMG][/IMG]
Old Jun 6, 2008 | 08:07 AM
joe flannery's Avatar
joe flannery
That is an easy one. The side of the clutch disc - where the springs in the hub sit higher- fits into the pressure plate, This way the other side of the disc will lay flat on the flywheel. Lay the disc against the fly wheel. Flip it both ways. You will under stand immediately which way it must go. If you were to install it backwards- the clutch facing will never come in contact with the flywheel there will be a gap caused by the hub making contact rather than the friction material on the clutch disc.
You will be happy with your Center Force clutch . I have one in one of my cars. It has decent pressure not too hard on your leg and grips very well.
Old Jun 6, 2008 | 09:12 AM
Amelio's Avatar
Amelio
Also be sure to wipe your flywheel and pressure plate with brake clean, it needs to be grease/dirt free. I am not sure the tq rating for the bolts are I would guess at atleast 50-70ft pounds I have a book with all that info but it is at home. Yes deffinitely use Locktite!!!
Good luck with your install
Old Jun 7, 2008 | 07:20 PM
madvette74's Avatar
madvette74
does any grease get put on the throw out bearing???
Old Jun 7, 2008 | 07:32 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
No, but use a new one.
Old Jun 7, 2008 | 10:35 PM
PeteZO6's Avatar
PeteZO6
Chevrolet shop manual says to pack the recess (groove) on the ID of the release bearing (throwout bearing), and to coat the OD groove with grease. On Corvette models, the manual says use Moly grease. Page 7-3, 1969 Chassis Service Manual.
Cheers,
Pete
PS. I can scan and post the image showing the throwout bearing and where to apply the grease if you would like. I need to change computers to do that - just PM me.
Old Jun 7, 2008 | 10:42 PM
BB427's Avatar
BB427
40lbsof q just installed mine today but to be honest I just did it by feel after easy each bolt in bit by bit star patten once the plate made contact I just wreched each one a light pull tight till the flywheel was about to move
To need help with installing clutch disc
