diff crossmember reinforcing kit
Old Jun 6, 2008 | 11:34 PM
Andy&Kelly's Avatar
Andy&Kelly
Default diff crossmember reinforcing kit
Hi All.
I ordered a differential cross member reinforcing kit from corvette central, but am a bit worried. Instead of giving me 2 studs and 4 nuts like they list in the catalog, they supplied me with 2 bolts. Has anyone else gotten them with the bolts and felt they will hold up?
Thanks,
Andy
Old Jun 6, 2008 | 11:58 PM
DJordan442's Avatar
DJordan442
should be 2 bolts, 2 lock washers (i think), and 2 large aluminum discs. the discs provide the reinforcement for the OEM bushings. i got them from CC and they install easily. i painted the discs black. good luck
Old Jun 7, 2008 | 01:53 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
I would call them to get the correct studs. I know VBP has them.
Old Jun 7, 2008 | 07:40 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I know I feel better using studs. PM me if you can't find what you need.
Old Jun 8, 2008 | 06:44 AM
WESCH's Avatar
WESCH
Hi
Just for my info, why would studs be better than bolts ?
Stronger ? Or can't bottom out like too long bolts or ?
Günther
Old Jun 8, 2008 | 08:48 AM
Andy&Kelly's Avatar
Andy&Kelly
Thanks guys, tried to call corvette central saturday morning, didnt answer phones, will do on monday
Gunther, having a stud with 2 nuts will bolt the mount in the factory cushion as well as at the disc that strengthens it. One bolt might be prone to flex and brake at some point as the head of the and the threaded part in the cross member have a gap.
Originally Posted by WESCH
Hi
Günther
Old Jun 8, 2008 | 11:38 AM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
CC customer non-service is not "in" on Saturdays. I don't use CC anymore because of many order problems during my restro.
To diff crossmember reinforcing kit
