81 vette codes
Old Jun 8, 2008 | 09:41 PM
BERIN's Avatar
BERIN
Default 81 vette codes
Anyone have the codes and what they stand for. Mine just started putting out code 15.
Old Jun 8, 2008 | 10:55 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Open coolant sensor circuit.
I can't remember which of the many coolant sensors this one reads off of, but check the ones in the heads to make sure you haven't pulled a wire off of one.
Old Jun 9, 2008 | 02:16 PM
Dirtbuster1's Avatar
Dirtbuster1
Code 15 is the CTS open. The sensor cold should read around 3000 ohms. If it reads that check for a wiring problem. Don't know if you have the old or new weather type plug. Make sure that the connectors are making contact with the pins. It is located on the front of the intake just left of & below the the thermostat housing. 12 bucks for a new one.
Old Jun 9, 2008 | 02:38 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
http://www.corvetteflorida.com/forum...read.php?t=977
Old Jun 9, 2008 | 09:19 PM
BERIN's Avatar
BERIN
Thanks everyone
Old Jun 9, 2008 | 09:23 PM
Jud Chapin's Avatar
Jud Chapin
You are welcome and good luck with your problem.
To 81 vette codes
