81 dash brake light on
Old Jun 9, 2008 | 09:07 PM
Dante7's Avatar
Dante7
Default 81 dash brake light on
hey guys my friends 81 brake light right between the tach and speedo is on and will not shut off and i tried to mess with it but could not figure it out... Are the 81's like my 75 where that just means the parking brake is on but i tried to mess with the little button beside the parking brake and it would not go off either..
Old Jun 9, 2008 | 09:32 PM
...Roger...'s Avatar
...Roger...
It also means there is a different pressure between the front brakes and rear.Probably have some air in the system.Most likely the rear.
Old Jun 9, 2008 | 09:52 PM
Oldguard 7's Avatar
Oldguard 7
Yup it's air more than likely. Bleed your brakes and reset the brake warning light /pressure differential switch with a heavy brake application.
Old Jun 10, 2008 | 04:11 PM
darklordftt's Avatar
darklordftt
Happened on my '81 also. The master cylinder had to be replaced.
To 81 dash brake light on
