Fan Clutch question ZZ4 crate engine
Old Jun 10, 2008 | 09:52 AM
DonW's Avatar
DonW
Default Fan Clutch question ZZ4 crate engine
My brother has a 79 with a ZZ4 crate engine with a direct drive fan. What is the process for replacing it with a fan with a clutch? Thanks.
Old Jun 10, 2008 | 12:27 PM
TopGunn's Avatar
TopGunn
I'm just taking a stab here but I'd think just remove the fan and spacer block and replace it with the clutch assembly. I'm not sure if the fan blades are the same but I bet they are. I used the same fan and clutch from my stock L-48 on my ZZ4 so there's nothing special about the engine. I assume you already have the short waterpump.
Old Jun 10, 2008 | 02:50 PM
Binnie77's Avatar
Binnie77
To Fan Clutch question ZZ4 crate engine
