Broken Bleeder Help
Old Jun 10, 2008 | 10:29 AM
bmanops's Avatar
bmanops
Default Broken Bleeder Help
I have a couple of broken bleeder screws. Apparently i didn't learn a good enough lesson when i broke the first one. Of course they are on two different calipers.
I have an easy out broken off in the first one, and am in the process of removing that, which is not a fun task. I tried to drill out the second one and tap out the last bit of metal, but i think i did too much damage in the process for things to work properly.
My next hope was to use bleeder repair kits.
I have had to drill down a bit in the process of trying to remove the broken bleeders, and would like to drill down further to clean things out and have a deep enough hole to allow me to tap for the repair.
What i would like to know though, is if anyone has used the bleeder repair kits. Does the repair kit include the mechanism for sealing the bleeder when it is screwed in, or does it rely on the bottom area of the hole remaining intact for a seal? Also, it seems like the entire repair would then need to be centered properly above the sealing hole within the caliper.
I don't know exactly how the bleeders work, but i assume when you tighten them, the hole in the bottom portion of the bleeder is pushed down into a cup that seals the hole?
For the record, let me just say. Breaking off an easy out in there is definitely something to try to avoid doing
Old Jun 10, 2008 | 10:34 AM
Durango_Boy's Avatar
Durango_Boy
You know it might be easier to find two GM stock calipers used and just have them sleeved, rebuilt, and installed. I would rather have different calipers than repaired bleeder bores. I know there is a large cost difference but that's how I personally would do it.
Just an idea.
Old Jun 10, 2008 | 11:07 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You might want to consider stainless steel bleeders. You won't have this trouble again.
Old Jun 10, 2008 | 12:08 PM
desi's Avatar
desi
Read this post... http://forums.corvetteforum.com/show....php?t=1788658
Old Jun 10, 2008 | 12:55 PM
pbcanney's Avatar
pbcanney
I have never ever had any success removing a broken bleeder with an easy out.
never
ever
Old Jun 10, 2008 | 01:10 PM
pws69's Avatar
pws69
never
ever
the Easy Out just pushes the soft walls of the bleeder tighter against the hole.
Old Jun 10, 2008 | 01:56 PM
SH-60B's Avatar
SH-60B
I immediatly just buy re-built calipers so I can get on with it.
Old Jun 10, 2008 | 06:24 PM
bmanops's Avatar
bmanops
Thanks for the input. Looks like I'll be buying a couple of replacements.
I wonder if two half calipers can get a core refund
Old Jun 10, 2008 | 06:31 PM
jdmick's Avatar
jdmick
The repair kits are certainly a low cost solution but I'd be a little concerned about metal flakes from drilling remaining in the caliper even after bleeding them. I've never tried a repair kit so maybe that's not a problem??
Old Jun 10, 2008 | 07:08 PM
LYLE's Avatar
LYLE
Exchange both of them at Auto Zone they won't care about the bleeders. The ones they sell are sleeved.
To Broken Bleeder Help
