1975 Vette/Hood Clearance Question....
Old Jun 10, 2008 | 11:52 AM
BrandonATK's Avatar
BrandonATK
Default 1975 Vette/Hood Clearance Question....
Hey guys,
Im not all up to par on the clearance issues on the vettes. If a newer Vortec motor is installed on a 1975 Vette are there hood clearance issues to look out for with say a Weiand Dual Plane Intake?
Thanks in advance
Brandon.
Old Jun 10, 2008 | 12:17 PM
TopGunn's Avatar
TopGunn
I know this isn't a direct answer to your question but I have a 75 w/ZZ4, Brodix heads and Weiand intake + QJet and no problems, plenty of room.
Old Jun 10, 2008 | 12:24 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Vettes in 1975-1979 had a slightly higher hood. Even a Performer RPM manifold with a Q-jet or Holley and a 14x3 air filter will clear as long as a dropped base air cleaner is used.
Old Jun 10, 2008 | 12:31 PM
BrandonATK's Avatar
BrandonATK
Awesome! Thanks alot for the info guys!
Brandon
Old Jun 10, 2008 | 01:49 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Don't forget to use the "plumber's putty" test to see exactly how much clearance you have.
Old Jun 11, 2008 | 03:57 AM
SteveG75's Avatar
SteveG75
1975 Corvette, stock hood, Performer RPM Q-Jet 7104, Q-Jet, Low Profile Moroso Racing Aircleaner with 3" filter.
3/4" clearance at the front of the aircleaner.
Just had to dimple the base a little for clearance with the accelerator pump arm.
Old Jun 11, 2008 | 08:33 AM
vett us all's Avatar
vett us all
I Used A Rotozip To Fix My Hood Too Breather Clearance Issues On My 73. K&N 4" Filter.
Old Jun 12, 2008 | 09:10 AM
BrandonATK's Avatar
BrandonATK
Would there be any issues with the radiator installing a serp pully kit?
Old Jun 12, 2008 | 09:45 AM
Durango_Boy's Avatar
Durango_Boy
Nope. I just built and helped install a Vortec 350 in a 1974 Vette. This Vette though has a Stinger hood, which has LESS clearance than the stock hood and an RMP intake and GM F-body serp fits just fine. You'll have plenty of room for the crank pulley and power steering pulley, and if you flip the smog delete pulley it'll clear the upper A-arm.
To 1975 Vette/Hood Clearance Question....
