68 327 large journal 4 bolt main???
Old Jun 12, 2008 | 12:37 PM
BLOCKMAN's Avatar
BLOCKMAN
Default 68 327 large journal 4 bolt main???
Was there ever 4 bolt main large journal 327, I have seen one in a 60 series truck and it there a publication showing this.
Thanks for any help Carl
Old Jun 12, 2008 | 01:07 PM
GDaina's Avatar
GDaina
Yes
Old Jun 12, 2008 | 01:20 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Originally Posted by GDaina
Yes
there are several of us here who have them me included though mine i believe is a two bolt
Old Jun 12, 2008 | 01:42 PM
gkull's Avatar
gkull
They first came out in 68 in conjunction with the 4 bolt 350. GM realized that they had a problem with the small journal cranks breaking when people started hot rodding the 265, 283,302,327
Old Jun 12, 2008 | 02:37 PM
bashcraft's Avatar
bashcraft
I could be wrong, but I was under the impression that there were no 4 bolt 327's and all 302's were large journal.
Old Jun 12, 2008 | 02:50 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Your right there was not any four bolt 327's from the factory. But not all 302's are large journal but most are. There are a few very early 67 models with the small journal.The large journal cranks came about not from broken small steel cranks but rather from the longer stroke of the 350 and cast cranks but proved to be not needed but remains anyway.
Old Jun 12, 2008 | 02:56 PM
stingr69's Avatar
stingr69
I do not think there were ever any 327's with 4 bolt mains from the factory. You could build yourself one pretty easily with a large journal 3.25" stroke crank and a 4 bolt main 350 block but none were built by GM. The large journal blocks started exclusively with 350 SS Camaros in 1967. The 327 got large journals in '68 and early '69 before being discontinued but never had 4 bolt mains.
-Mark.
Old Jun 12, 2008 | 02:59 PM
Little Mouse's Avatar
Little Mouse
I don't know about the 4 bolt block, but in 76 I used a large journal forged
327 crank to build myself a 331 using a 4 bolt block, also a friend of mine I shared a shop with built a 348 using a 4.125 400 block he used a large journal 327 crank with a special set of bearings made back then that would allow the 2.45 crank to go in the 2.65 main 400 block.
Old Jun 12, 2008 | 03:10 PM
bashcraft's Avatar
bashcraft
307 cranks were the same as a large journal 327.
Old Jun 12, 2008 | 03:43 PM
gkull's Avatar
gkull
I could be wrong on the 4 bolt block, but i had a large journal 327 steel crank
Old Jun 12, 2008 | 03:51 PM
Manuel Azevedo
You could have sense they did come both ways.
Old Jun 12, 2008 | 03:53 PM
Little Mouse
Any Idea what it came out of The steel crank just showed up at the machine shop where I worked. 307 cranks were probably all cast cranks.
Old Jun 12, 2008 | 03:54 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I just bought a 68 327 C-10 block. It has two bolt mains and a large journal forged crank.
Old Jun 12, 2008 | 04:37 PM
markdtn's Avatar
markdtn
Never any 327 Large Journal 4-bolt engines in cars, that is a fact. They can be built with a LG 327 or 307 Crank and a 4-bolt 350 (4" bore) block. I have heard that there were some 60 series type dump trucks built in 69 that did have 327 LG 4-bolt with steel cranks, but I have never seen any proof. The big truck version 68-69 was the only one that had a LG forged crank, they were never in cars stock either to my knowledge.
Old Jun 12, 2008 | 05:11 PM
Manuel Azevedo
Dump 2.5 ton truck had them and also the 68 350hp 327ci.
Old Jun 12, 2008 | 09:52 PM
BLOCKMAN's Avatar
BLOCKMAN
I just talked to a good friend of mine that builds a lot of performance engines and a I asked if he had ever seen a large journal 327 4 bolt main and he had one in the shop about 4 years ago and at that time he went through all the numbers and found it be all original. And thinks the customer still has it.
Rather then argue with me give him a call Bob Baily (Hi Tourque engines) 207-729-7755
And there is another friend of mine that has restored vettes all his life has a book from GM that tells how many were used in the 68 vettes and the 69"s were 350"s
He has built some for his customers but he said there were very few made he has the numbers.
Old Jun 13, 2008 | 07:37 AM
vettesbydesign's Avatar
vettesbydesign
I have never seen a large journal 4-bolt 327,but have also, heard of the heavy trucks.Also....heartd the other day that a guy was saling a 68 327 from a Cris Craft boat that was LG,and 4-bolt,but didn't see the engine.
Here is a stock bottom end from mid-68 327/350 horse vette.....
To 68 327 large journal 4 bolt main???
Old Jun 13, 2008 | 09:02 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
My best friend in high school had one of those 327 boat motors in his 70 Z28. He pulled the LT1 for safe keeping and would spin the hell out of that solid crank 327 motor. It was painful riding around. The think would shear rear studs. Pretty sure it was a four bolt main, because it was all he talked about.
Old Jun 13, 2008 | 09:20 AM
sundevil74's Avatar
sundevil74
I have such a long block for sale (1968). RPO is L79. 2-bolt main block but the forged crank is large journal (or some folks call them "medium" journal cranks; guess there are cranks with even larger journals.)
Old Jun 13, 2008 | 09:31 AM
L88Plus's Avatar
L88Plus
400's are larger, but most just refer to small and large on 350's and smaller. I had a 327 large journal forged crank once, too. Should have kept it and used it with spacers in a 400 block, but when somebody waves cash in front of me...
