Posing another headlight problem
Old Jun 12, 2008 | 12:48 PM
mailbox1024's Avatar
mailbox1024
Default Posing another headlight problem
Have a 1972 Corvette. Each time i start the car, my headlights pop up. I have the routing and troubleshooting book, all the hoses seem to be hooked up and in good shape. The headlights will not go down on their own either after i turn off the engine. I was just wondering if anyone out there has had a similar problem and can point me in the right direction as to a possible fix or where to look. The lights have always worked well in the past until this year. Yes, i can turn the lights on, and yes i have checked the manual overide switch for malfunction and it is not in the overide position.
Thanks in advance for any ideas.....Ron
Old Jun 12, 2008 | 01:27 PM
...Roger...'s Avatar
...Roger...
You have a leak in the system if they work with the engine running but wont do 1 cycle after the engine is off.
Old Jun 12, 2008 | 03:38 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Sounds like a bad check valve to me
Old Jun 12, 2008 | 06:23 PM
hugie82's Avatar
hugie82
Mine use to stick in the up position. I had to lift up on it and then let go to make it go down. I replaced the plastic bushings and lubed her up. Works good now.
Old Jun 13, 2008 | 11:12 AM
mailbox1024
No, mine move easily up and down, only problem is when i 1st start engine the headlights pop up but they do not go down when i turn off the engine.
No vacuum leaks either, checked entire system and hoses fairly new as well.
Old Jun 13, 2008 | 11:13 AM
mailbox1024
Any idea which check valve? And how can i isolate it?
Old Jun 13, 2008 | 11:17 AM
...Roger...
Your not getting vacuum on the small white stripped hose going out to the relays between the headlights.Do you have your pulldown pushed in?
Old Jun 13, 2008 | 11:55 PM
mailbox1024
no, the hold down is not pushed in. That was the 1st thing i checked.
Old Jun 14, 2008 | 07:34 AM
...Roger...
You say it is not pushed in.
The pulldown valve under the dash "needs" to be pushed in or up.
If it is pulled out or down it is locking the headlights in the up position.
Old Jun 16, 2008 | 10:12 AM
mailbox1024
I tried pushing the manual valve both up and down, still the same problem. I am at a huge loss for any relief. Please help with any other suggestions...Ron
Old Jun 16, 2008 | 10:17 AM
TopGunn's Avatar
TopGunn
I agree, replace the check valve in the main vac line.
http://www.ecklers.com/product.asp?p...7&dept_id=1326
Old Jun 16, 2008 | 10:20 AM
sweethence's Avatar
sweethence
the check valve is located right off of teh manifold vaccuum fitting right after a short piece of hose
Old Jun 16, 2008 | 05:08 PM
wjsullivan's Avatar
wjsullivan
My '75 has a similar issue. I've isolated it to two items, the override valve and the main switch.
My override valve was shot. When I replaced it I also put some rtv on it to make sure I had a really good seal. The issue got better.
The main switch in the dash is also an issue. I ran into a guy who was buying his 2nd replacement switch for his '74. He showed me the switch. It had two parts that appeared to be pressed together (top and bottom I think). On his previous 2 switches that press fit had failed so this time he was going to put some rtv on the seam to make sure it stayed sealed.
Old Jun 16, 2008 | 05:26 PM
thegazman's Avatar
thegazman
Default thegazman
You mentioned that your lights do not go down when you turn off the engine. What might help you with trouble shooting to understand that vacuum closes the headlights and lack of vacuum allows them to spring open. If they are closed when you shut the engine off and open after the car sets for awhile your check valve is probably leaking air into the vacuum system. The reason the lights close with vacuum is to allow you to still have headlights at night if a hose came of or something breaks in the vacuum system. It would be tough driving on a curvy road at night and all of sudden your lights closed.
Old Jun 18, 2008 | 04:45 PM
mailbox1024
Fixed the problem. Had no vacuum at the headlight switch. Routed a new hose w/ vacuum to the headlight switch, it cured the problem. Headlights work fine now!
thanks all for the input.
Old Jun 18, 2008 | 06:52 PM
Sully1882's Avatar
Sully1882
you lucky dog.... ha ha... i still can't figure out what is wrong with mine... mine is doing the same thing where the headlights pop up upon starting the car without pulling any switch... and do not go down when I do pull the switch and then push it back in....although I did find that my check valve is bad, but from what I understand with the vac system that would not be the cause of the small white vac line not sending vacuum to the relay and causing the headlights to pop up... I guess i will have to pull my headlight switch again and check the vacuum there like MAILBOX1024 did... any other ideas????
thanks
sully
Old Jun 19, 2008 | 08:48 PM
mailbox1024
Actually i found mine by accident. When i was looking under the dash at the manual switch, i unplugged the vacuum ports at both ends of the manual over ride and i put them together. The headlights instantly dropped down and went back up when i unplugged the vacuum. This told me i was not getting vacuum at the headlight switch. I removed the dash to get access to the headlight switch, found no vacuum at either port. So i installed a T fitting and tapped into the wiper door vacuum, (which was eliminated when i bought the car a few years ago anyway), and then the headlight switch activated the headlight doors upon my command and not when i start the engine.
Just lucky i guess.
Ron...NJ
To Posing another headlight problem
