Special O-Rings inside Calipers????????
Old Jun 12, 2008 | 01:08 PM
LoneStar26047's Avatar
LoneStar26047
Default Special O-Rings inside Calipers????????
Rookie mistake...I broke the seal in my brake caliper, instead of removing it , and after bleeding the brakes I developed air in the line. I never messed with the piston rings so my guess is the small o-ring that seals the two caliper halves isn't sealing any longer. I have a bunch of generic o-rings in the barn but I don't know if DOT4 brake fluid will dissolve them. I really don't want to buy a whole rebuild kit just to get one small o-ring. Does anyone know if brake fluid is likely to dissolve this ring? Going to go myself in the head now!
Old Jun 12, 2008 | 01:39 PM
BB68Vett's Avatar
BB68Vett
I went to NAPA to buy them for my calipers. Just bring in one good one and match it up. No problems and its been several years.
Old Jun 13, 2008 | 12:16 AM
spookytooth's Avatar
spookytooth
Check to make sure the rubber compound is either
Ethylene Propylene (EPR) or Styrene Butadiene (SBR)
If the guys at the auto place don't know, go to an
industrial supply company
Old Jun 13, 2008 | 12:29 PM
LoneStar26047
Both great answers with a couple of better options than I had before!
Thanks so much!
To Special O-Rings inside Calipers????????
