Fuse box on 68
Old Jun 12, 2008 | 09:12 PM
khubert035's Avatar
khubert035
Default Fuse box on 68
Can anyone tell me how the engine harness plugs into the fuse box....is it held by screws etc. ??? I am trying to get the fuse panel out and I am hung up. Any help is appreciated.
Old Jun 12, 2008 | 09:44 PM
Blue68's Avatar
Blue68
St. Jude Donor '08
khubert,
I have the AIM for the 68. And I live not too far from you. Give me a shout through the email and I can stop by this weekend.
There is a screw that goes from the engine bay through the firewall. That is probably what is hanging you up. Anyway if you want some help then send me an email. wsh68@hotmail.
wayne h.
Old Jun 12, 2008 | 11:09 PM
1Fordman's Avatar
1Fordman
The screw that holds the outside connector to the fuse box inside has a 3/8 head on it. It's a pain to get to but can be done. If your vacuum tank is out it's much easier to access.
Old Jun 12, 2008 | 11:21 PM
sly vette's Avatar
sly vette
Yeah you'll bet there is nothing there due to all the crud, if yours was like mine when I took mine apart,
but there is a screw!!!
Old Jun 12, 2008 | 11:29 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
It's there, right in the middle. I used a 1/4" rachet and a deep socket. I want to say it's 3/8's of 7/16". Didn't have to remove the vacuum tank, but it is easier to reach underneath.
Old Jun 13, 2008 | 12:37 PM
khubert035's Avatar
khubert035
Thanks to everyone, knew you all would come through. It was a PITA to get to, but finally got it. It is a 3/8, and you definitely need an extension. Removing the vac tank would make it real easy, but thats not the Vette way. Thanks again for all your help.
To Fuse box on 68
