Engine Question
Old Jun 15, 2008 | 02:00 PM
69 Convertible's Avatar
69 Convertible
Default Engine Question
Just got my vette running since last July. Fire up the rebuilt motor and brought it to the shop to have the pipes welded to the new headers. It has let than 20 miles on the motor. Went to pick it up and notice that the passenger side was smoking alot while idling. With the wife following me back home, she said that it just smoked very little. Is this normal due to it being a fresh motor and should stop when the rings seal? Tony
Old Jun 15, 2008 | 02:37 PM
Durango_Boy's Avatar
Durango_Boy
How fresh of an engine build is it, and what procedure did you use to break it in? Some engine details please? New, used parts?
What color was the smoke?
Old Jun 15, 2008 | 02:59 PM
69 Convertible
The engine was rebuilt in Dec. and I just got it running last week. I had comp roller tip rockers and a Crane hyd roller set installed. Used the engine breakin oil the builder sold me. Primed the the motor till I saw the oil coming out of the rockers. Had trouble starting it, so it was cranking alittle bit before I got it started.Looked at the gauge and had high oil pressure while I was trying to start it. When it fired up it was running between 1,500 to 2,000 rpm. for ten min maybe fifteen min. I read and the engine builder said that there was no breakin for the roller cam so I didn't do the 2,000 rmp for 20 mins. Took the vette for a drive around the block to make sure everything was working. Then drove down to the shop the following week for the pipes to be welded. Then home. Plan to take it out today. Tony
Old Jun 15, 2008 | 03:24 PM
GDaina's Avatar
GDaina
Moly rings need a fine crosshatch hone as they will seat instantly...you might have a seating problem or a valve seal...pull the plugs and see what cyl is smoking
Old Jun 15, 2008 | 03:25 PM
69 Convertible
The smoke wasn't white. Maybe grayish? Just checked the oil from the dipstick and it looks like when I just put it in, clean. The parts internally are all new. Forged pistons, 10.50 to 1 , roller lifter and rockers etc. Stock motor with mild cam.
Old Jun 15, 2008 | 03:34 PM
69 Convertible
wife says white smoke, not gray. my mistake.
Old Jun 15, 2008 | 03:53 PM
Durango_Boy
It's possible you have a small water leak. White smoke is indicative of water in the combustion chamber. Now it may not be something as bad as a head gasket or a crack int eh heads or block. If the head bolts weren't sealed properly, they will allow water to creep up the threads where it mixes with the oil that comes up to oil the rockers and valves.
The fix is simply pulling the head bolts, adding a good amount of thread sealant, and re-torquing them.
This may not be your problem, but white smoke is probably water.
For future reference, you still want to do the high RPM driving to properly seat the piston rings. You want a load on the engine, so traveling at speed, varying high RPMs, which builds cylinder pressure.
Old Jun 15, 2008 | 04:09 PM
69 Convertible
So there should be no smoke at all? And the high rmp breakin of the rings, like max. 60-65mph varying the speed? For 500 mile or longer?
Old Jun 15, 2008 | 04:32 PM
bonehead2's Avatar
bonehead2
The above is correct,also pull some plugs and see if it's burning water. Who put the intake on?.
Old Jun 15, 2008 | 05:09 PM
69 Convertible
The shop rebuilt the motor so I have their warranty. I going to take for a run and see what happens. Taking the wife along. The last time I went for a cruise with the wife was when I blew the motor. One year later, another cruise. So this is our maiden voyage together again. Crossing my fingers. She's caring the Bible LOL. Let you guys know how it went and if the smoke cleared up. Tony
Old Jun 15, 2008 | 07:10 PM
69 Convertible
Just got back! My update: In the beginning I could see the smoke blowing abouts at the back of the vette. Still crossing our fingers, as we pressed on the smoke was growing less. When we finally got to San Francisco, the smoke was GONE! So that's good news right? I'm still going to monitor it. Break it in and make sure everything is alright. One thing I have to say is that the Classic Chevy 5 TKO600 is GREAT! The rpm is down. I'm glad I when ahead and installed it. Now I can cruise 70-80mph
(didn't do it yet though) One question left, on the temp gauge, you have 100 and then a hash mark then the 210. What's the temp. at the hash mark? The vettes running inbetween 100 and the hash mark. I have to get the infra temp gauge to see that it's running at. New water pump and radiator. Thanks for the help. Tony
To Engine Question
