69 Tranny removal Help!!
Old Jun 15, 2008 | 05:07 PM
dd vette's Avatar
dd vette
Default 69 Tranny removal Help!!
Need to remove the tranny as it has a leak in the front casing. Will it pull back enough once I remove the driveshaft? Don't want to start moving the engine. Thanks
Old Jun 15, 2008 | 05:36 PM
Durango_Boy's Avatar
Durango_Boy
Automatic I assume? The cross member will unbolt to aid in removal, so once the drive shaft is out, and the transmission is supported and unbolted from the engine you can slide it back a bit and lower it. Don't forget to unhook the shifter cable, detent, cooler lines, speedo cable, vacuum line, and the wiring.
The front seal is not a hard seal to replace.
Old Jun 15, 2008 | 07:16 PM
dd vette's Avatar
dd vette
ooops sorry but it's a 4speed. There was a small ammount of silicone on the front of the tranny. Noticed it when the engine was out. Should have checked it out back then.
Old Jun 15, 2008 | 07:46 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Yes, it can be done. I just did it this past winter on my 69. Remove all linkage & related hardware. Remove the backup switch and bracket and any other hardware on the tranny. Slide the tranny back as far as it will go then twist it. Once the pilot bearing clears, move the tranny toward the passenger side & drop it down.
To 69 Tranny removal Help!!
