Fuel filter question
Pros & cons.
Put it right at the end of the metal line on the frame. Where the rubber 'S' shaped hose hooks up. Or back at the rear of the car, right after the fuel sending unit. Both of these places have rubber lines from the factory that need to be checked with normal maintenance items. Why check 3 places when you already have a spot you could add one?
It's never a good idea to have to rubber lines touching and rubbing, they will wear through, at the very least get flat spots. Not a good idea at all, when one is hot water from the engine block that makes the heater, hot, and the other is fuel... (gas boils at 140* IIRC)
Only pro I can think of is, your not going to forget about changing it, cause every time you open the hood you will see it.
I had a set up like running man, recently got the proper line and filter for the carb and put a new in-line filter in the rear of the car, where I described above.
I believe that bracket is/was for the A.I.R. pump. Are you going to put it back on there?
"When you do, you will have to either raise the bottom of the fuel pump above top of the fuel in the tank, or clamp the 3/8" inlet hose (the larger one) at the pump, if your is new and in good shape, or the gas tank will empty on to the ground through the fuel line fitting. Not fun."
To further explain this, cause I looked at it and did the classic 'huh'. Gravity. The tank is higher than the pump, if you pull the fuel line off (pump to carb section) you need to stop the flow of fuel. I'd plug the 'S' shaped hose or squeeze it with a pair of vise grips. If you just squeeze it, one less thing to hook back up.
I remember hacking my bent and twisted fuel line off with a dremel, while it was still on the car.... I don't know what I was thinking at the time, sparks from dremel, still on the car, liquid fuel and vapors... All I did was wipe the line down ever so often to dry the outside and kept cutting.
You do watcha gotta do, when it's your daily driver.
But I think he may be disappointedly if he doesn't like the set up and has to go back and buy another fuel line after he cuts his. The two spots I mentioned are fairly easy to get to, it's your call, Vet76te.
Pros & cons.
If you'e dead set against running the in-line filter in the Q-Jet (why not?) then I'd run the pump-to-carb lines that 68 and 69 SB Q-Jet Vettes used which had an inline filter, GF-432, that uses flair fittings.
Yep.
