Check Timing - How to?
Old Jun 15, 2008 | 11:04 PM
TyCor's Avatar
TyCor
Default Check Timing - How to?
Can anyone give me the basics for checking/setting the timing on my '77? I have read several posts, but they explain bow to build an iginition system, I just want to set the timing and move on to other projects.
Old Jun 16, 2008 | 12:35 AM
birdsmith's Avatar
birdsmith
Check the timing by connecting the positive(red) lead of a timing light to the positive side of your battery, negative to negative, and the 'trigger' lead around the #1 spark plug wire. Disconnect and cap off your vacuum advance hose, start the engine, point the light at the timing tab on the left front corner of your engine (make sure the wires from the timing light don't get tangled up in your fan!!) and pull the trigger. The light will come on every time the #1 plug fires producing a strobe effect that will allow you to read your timing indication at idle. Opening the throttle while doing this will allow you to read total advance (if you have a means of indicating degrees on your balancer-the timing tab runs out at about ten degrees). Reconnecting the vacuum advance hose will allow you to read vacuum advance as well.
Old Jun 16, 2008 | 01:23 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Check out the "Sticky" thread (2nd from the top of the first page)...It gives you EVERYTHING you want to know (and was afraid to ask) about timing...
Good Luck!
To Check Timing - How to?
