a/c
Old Jun 17, 2008 | 11:21 AM
lasertecboating's Avatar
lasertecboating
Cruising
Default a/c
my ac just quit want engaged or anything
Old Jun 17, 2008 | 11:23 AM
lasertecboating
Cruising
i have a 77 and my ac just quit needs some help was working fine.check the wiring its all good
Old Jun 17, 2008 | 11:34 AM
71rdster's Avatar
71rdster
Low pressure switch shut off. If you can jumper the switch and your compressor kicks in, you are low on freon, and possibly have a leak.
Old Jun 17, 2008 | 12:13 PM
TopGunn's Avatar
TopGunn
Low pressure switch is located just under the fender on the passenger side. Make up a small jumper wire, remove the two wire plug from the switch and install the jumper wire in the plug. If the compressor starts then you're low on refrigerant. Don't run it like that, it's a safety feature.
Old Jun 17, 2008 | 01:21 PM
lasertecboating
Cruising
thank u very much for the info.hope i can return the fav. some day
Old Jun 17, 2008 | 01:22 PM
lasertecboating
Cruising
Old Jun 17, 2008 | 01:38 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
How about taking a few minutes and fill out your profile. That way, it will help forum members help you.
Old Jun 17, 2008 | 01:54 PM
TopGunn's Avatar
TopGunn
Let us know what happens, it could be something else also.
Good luck
Old Jun 17, 2008 | 03:11 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
one thing to keep in mind is that the switch can fail to and jumping the switch will not let you know wether it is the switch or low on freon. Really need to check it with a set of gauges.
Neal
Old Jun 17, 2008 | 04:21 PM
Jud Chapin's Avatar
Jud Chapin
Neal
If your system has refrigerant, you need to engage the compressor and check the pressures with gauges.
To a/c
