Is New GM really imported junk? I need help
Old Jun 18, 2008 | 12:51 PM
red70stingray's Avatar
red70stingray
Default Is New GM really imported junk? I need help
Well...
I need new outter door handles for my 70 coupe. I have seen them ranging in price from 250.00 a pair, for GM resteration parts, to 32.00 a pair.
Are they all the same?, i mean is GM having them made elsewear, putting them in a nice box and skyrocketing the price? I want to buy a quality, nice fitting handle, but dont want to get fooled by a cheap import in a nice GM box?
Any advice, prior experiance buying these would be greatly appreciated.....
Old Jun 18, 2008 | 12:56 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
you might call up say willcox or corvette america or someone like that.. personally though, i have no clue
Old Jun 18, 2008 | 12:59 PM
red70stingray
I was wondering if the markings were differant on the underside depending who made them
Old Jun 18, 2008 | 01:04 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I personally don't think GM is reducing the quality of their parts no matter where they are made. They have too much to lose in doing so. Buying from other manufacturers is another story.
Old Jun 18, 2008 | 01:57 PM
zwede's Avatar
zwede
I've seen the cheap door handles and the expensive ones. Don't know where the expensive ones were made, but the quality was much, much better. Don't get the cheapos.
Old Jun 18, 2008 | 02:54 PM
red70stingray
ttt
Old Jun 18, 2008 | 03:01 PM
70LT1VET's Avatar
70LT1VET
You can also try Paragon Corvette Reproductions....I know they sell several GM Restorations parts...not sure about the handles
Old Jun 18, 2008 | 03:57 PM
kdf1986's Avatar
kdf1986
some of the reproduction parts are either thin metal, or lower grade potmetal.
The original GM parts seem to be better constructed, and have use a thicker material. The same is true with some other material.
example 1. The exhaust bezels for my 73 look like thin aluminum , but the originals on my 72 are 1/8 inch thick approx
example 2 On my 86 the replacement front air dam ABS Plastic shattered the first time it hit a curb stop. The 2nd replacement air dam was a OEM part at 3x the price and has had no cracks after 2 years of use.
kdf
Old Jun 18, 2008 | 04:09 PM
GD70's Avatar
GD70
Paragon has them listed without ("imported") next to the item #'s. You may want to call them to make sure, or they may also have used ones in good condition.
Good luck.
Glenn
Old Jun 18, 2008 | 04:25 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I would get the GM handles myself. The last set I purchased from my GM rep was $160 each, give or take a few pennies and they were for a 70 as well.
Old Jun 18, 2008 | 04:51 PM
mrvette's Avatar
mrvette
After I"m gone, telling my son to part the damn thing out, get more money THAT way......
Old Jun 18, 2008 | 06:25 PM
Thmprr's Avatar
Thmprr
The repro door handles are junk, the chrome is so bad that you can see scratches after one use! Otherwise, they work ok but I for one will be replacing them with OEM asap.
Old Jun 18, 2008 | 06:49 PM
red70stingray
I now know what direction to take... oem all the way...
Thank You!
Old Jun 18, 2008 | 09:15 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
contact wilcox they will know for sure
Old Jun 18, 2008 | 09:28 PM
dmayhew's Avatar
dmayhew
GM is not actually making these restoration parts as I understand it.
The are allowing select companies to reproduce them under license.
Having said that. I just purchased a RC-15 radiator cap that looks 100% dead on, HAs the arrows and the circles where they belong.It is a GM restoration part. Box marked GM restoration.
The part in side had a made in Tiawan sticker. I would have loved to not have seen that.
But the part is fine.
Paragon is licensed to reproduce the GM poducts.
David
Old Jun 18, 2008 | 09:34 PM
r3rep's Avatar
r3rep
Default AC Delco
I just got a set of AC Delco drilled and slotted rotors and guess what....MADE IN CHINA You cant get anything made in the US anymore.
Old Jun 19, 2008 | 11:40 AM
SH-60B's Avatar
SH-60B
I replaced the drivers side handle with a cheapo and the chrome is perfect after 6 years. It looks just like the original, I couldn't see any difference, and works just as it should.
To Is New GM really imported junk? I need help
