Head Gasket Matching Problem.
First, in the yellow squares, are a water port that doesn't match with the cutout in the head. Two per head, and one other that doesn't have a hole. I can enlarge the cutouts to match the openings in the head or will they be okay as is?
Also, I have shown a water port circled in red. That same red circle represents larger water ports UNDER the gasket, where a single tiny cutout exists. Should I open up those cutouts to match the water ports?
I have not checked these gaskets against the block yet but being that they are gaskets for a 400 they should match the block already.
Here are the pics, again, the yellow squares are the ports that don't match, and the red circles are where the ports are bigger than the cutouts.
The other 2 small ones are so that you can use the same gasket on both banks (cheaper to produce)
The yellow square being off, well that's nothing out of the ordinary. Those gaskets are made to work with any available head, there's a bit of tolerance in the placing of the jackets and holes depending on chamber shape and port shape (they're simply cast in) as such the shape isn't even consistent, some are round, some are sort of triangular...it differs per head.
Thank you, that was very good information.
I have seen gaskets not match before but this was more extreme than I had experienced and was wondering if I had a mismatch between the gaskets, or even the heads and the block. I've never built a 400 besides this one, and these certainly aren't stock 400 heads.
So basically I shouldn't have to do anything but mark and drill the steam holes.
The paper I read that outlined it showed that the steam holes closest to the bolt bosses needed to be drilled at a 45 degree angle away from them. As V-twin said, the other side straight down. I think so long as the bit doesn't get into the bolt boss it doesn't matter.
No this is mine. I built this 405 a few years ago, but stalled on the fuel injection setup. In the last few weeks I re-planned the build for more power, and changed to a carb setup with an option to go FI later.
It's a very different setup than what I am used to...lots of new things for me.
Any ideas? I straight in, and straight down, at the angle, but nothing. I don't want to punch into the center exhaust port passages.
http://www.gregsengine.com/350to400.htm
I know the article's captions read 10* but it sure looks like head's indexed about 30*
Yeah I have the location and the angles right on I think, but the depth of the second set is scaring me. Like I said I am already at almost a full 1" depth, which is considerably deeper than what I've read before. However, these are after market aluminum casting so there may be more material to drill through.
I checked with a local machine shop, they have never drilled steam holes in aluminum after market heads, and want $50 per head just in case something goes wrong so they can cover their own ***.
