correct oil pressure question
Old Jun 21, 2008 | 11:54 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
Default correct oil pressure question
just as the title states, what is correct oil pressure on a '79 auto?
with the engine completely off, im runnin 20.... on, i run 50-70. the car is new to me, and only know that the engine was rebuilt about 4 ears ago (have that receipt) though it doesnt say everything that was done.
i guess next question once correct is determined, is why am i running 20psi (or whatever) with the engine off.
Old Jun 22, 2008 | 03:47 AM
couperdecar's Avatar
couperdecar
My '79 runs about 40 psi with the engine running. No oil press when its off. Your gauge is wacked.
Old Jun 22, 2008 | 04:04 AM
chevr0letman's Avatar
chevr0letman
I agree, your gauge is whack.
Old Jun 22, 2008 | 09:07 AM
jb78L-82's Avatar
jb78L-82
I don't think your guage is incorrect! My 78's gauges when the ignition is turned off remain where they were when the car was running until the next time I start the car at which time they all reset to "0". I just went out to look at the gauges in the car sitting in the garage off and oil pressure shows 40, Temp about 175, and volts 14. When I start the car they all reset. Also, my oil pressure with a stock L-82 is about 40 lbs idling and 50-60 at high RPM with 20W-50 Racing Mobil 1.
Old Jun 22, 2008 | 09:36 AM
marshrat99's Avatar
marshrat99
Your oil pressure will depend upon the oil pump and RPM. My 79's engine is nothing close to the original L82 and uses a HV/LP Melling. According to my oil pressure guage, it runs 40lb at idle and 50lb at cruise. I could read the real pressures by hooking up a mechanical, calibrated guage but haven't done so.
As far at the guage not zeroing when the key is turned off, then I agree that mine does not but, if you turn the key off to kill then engine and then turn it to run without starting, the guage does drop all the way to zero.
Old Jun 22, 2008 | 09:39 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Originally Posted by jb78L-82
I don't think your guage is incorrect! My 78's gauges when the ignition is turned off remain where they were when the car was running until the next time I start the car at which time they all reset to "0". 1.
Same here for my '76.
Old Jun 22, 2008 | 10:44 AM
joshtried's Avatar
joshtried
let me rephrase that one... my gauge NEVER goes to 0. sounds like gauge is whack according to a few of ya..
isnt there a way to test.. like ground should go one wa, and positive another.. or somethin like that
Old Jun 23, 2008 | 06:19 AM
BassCat's Avatar
BassCat
The guage on my 77 was all over the place when I bought it. Turned out it was the oil sending unit, not the actual guage. I screwed a new one into the engine and it fixed it.
Old Jun 23, 2008 | 12:22 PM
7T1vette's Avatar
7T1vette
I think that you are saying the gauge reads 20 psi when the engine is not running...but the key is turned ON. I suspect that the wire terminal/connection going to the temp sensor is dirty or that someone has put teflon tape/sealant on the threads of the sensor when it was installed into the block. The threads should be CLEAN, as that is the ground connection for the circuit.
Old Jun 23, 2008 | 12:27 PM
7T1vette's Avatar
7T1vette
Nevermind. You said oil pressure...and my brain is 'thinking' water temp. The only reason for the oil pressure gauge to read anything with engine off and ignition turned on is that the gauge is broken or the needle has been positioned in error (slipped or moved by someone).
To correct oil pressure question
