Coolant overflow tank
Old Dec 23, 2001 | 11:16 PM
NJ74STINGRAY's Avatar
NJ74STINGRAY
Default Coolant overflow tank
HI, My coolant overflow tank needs to be replaced.It looks like there is only 3 u-nuts holding it.It is hard to see because its under the fender and the ac stuff is in the way.Has any done this and what is involved or is it harder to do than it looks.Thanks Happy Holiday's to all >STW< Frank, :flag
Old Dec 24, 2001 | 04:12 AM
lou's Avatar
lou
Default Re: Coolant overflow tank (NJ74STINGRAY)
I did mine on my 80 fairly easy but I cheated. It is only three bolt easy to access in the wheel well. I removed the A/C hose from the back of the compressor and moved it out of the way to get it out. (The system is empty). It's probably different for your year but I thought I'd try to help. lou
Old Dec 24, 2001 | 10:26 AM
ED DINAPOLI's Avatar
ED DINAPOLI
Frank,
You are correct there are three bolts that hold the tank to the fender. They are accessed from under the fender and the fastners are on the tank. I have a used tank that is a little yellow if you need one.
Ed
Old Dec 24, 2001 | 10:29 AM
Green 79's Avatar
Green 79
Default Re: Coolant overflow tank (ED DINAPOLI)
I need to replace mine also. Just wondering how much a new one will cost???
Old Dec 24, 2001 | 10:30 AM
scottw's Avatar
scottw
I took mine off this weekend. Very simple. There are only the three nuts to take off. Took me longer to get the tire off than the overflow tank.
Old Dec 25, 2001 | 09:40 PM
NJ74STINGRAY
Default Re: Coolant overflow tank (scottw)
HI,Thanks for the reply's.I will give it a go as soon as the new one gets here.HI Ed,Thanks for the offer very much but before I posted I had ordered one from Riks.>So quick to spend my money<.Thanks again and hopefully see you at Mahwah again. >STW< Frank>
Old Dec 26, 2001 | 12:50 PM
PRNDL's Avatar
PRNDL
Default Re: Coolant overflow tank (Ed T)
Ed T, Isnt the correct factory color for the dozer "Schoolbus Yellow" ? Pls dont tell me you've done the aftermarket GI Joe conversion!! :lol:
MJ
To Coolant overflow tank
