brake
Old Jun 23, 2008 | 09:34 PM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Default brake
Folks I have a 79 and the right side calipers were holding the rotor. I replaced the calipers and still have some grabbing. The brake pedal is okay at first but after the engine is started it goes to the floor. Is it the master cylinder? If I bleed it, the rotor turns. Any body got any ideas?
Old Jun 23, 2008 | 11:03 PM
wombvette's Avatar
wombvette
Adjust the push rod so that when the brake is not applied the pickup hole vent in the bottom of the master cylinder is uncovered. This allows the fluid to be picked up and lets the fluid pressure balance itself. Then bleed the brakes to get the air out. Also check the flow through in the rubber lines.
Old Jun 24, 2008 | 06:33 PM
feb18blacksunday
Where is the push rod? in the front of the mc? My friend said that the line may be collapsing on the inside of the line.
Old Jun 24, 2008 | 07:29 PM
wombvette's Avatar
wombvette
You should check the rubber hoses first. Jack up the car. Apply the brakes. Then try to turn the wheels. If one or more is hard to turn, loosen the bleeder on that one and see if it releases. If so, it has bad hoses. If you find all of that OK, then go to the MC. If you look down in the bottom of the MC, you will see some holes. If the piston in the MC does not come back far enough to clear the holes, you will have to adjust the rod. Some are adjustable, some are not. You have to pull the MC off and forward to get to the rod.
Old Jun 24, 2008 | 08:32 PM
feb18blacksunday
Right side is not turning after the brake is applied. If I burp the bleeder it releases. I haven't checked the rears. When I have the engine on the brakes go all the way to the floor or the vacuum isn't working on the power booster.
I think i'll change the right side hose and see if it changes.
Old Jun 24, 2008 | 10:57 PM
wombvette's Avatar
wombvette
When you get the hoses changed out, then bleed the air out and the brakes will stay up.
Old Jun 24, 2008 | 11:50 PM
feb18blacksunday
Sweet I'll be on that tomorrow evening.
Old Jun 27, 2008 | 08:49 PM
feb18blacksunday
on all 4 or just the one replaced. Chiltons said just to bleed out the one changed. Plenty of petal now, but turn on the car and the petal goes to the floor. Do I still have air in the caliper?
Old Jun 28, 2008 | 02:54 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
I do think so...there is a procedure for bleeding i jinda forget but it should be in a manual...I think it starts inboard bleeder left rear then out board bleeder left rear left front then right rear & then the right front...something like that made a big difference for me
Old Jun 28, 2008 | 04:39 AM
81cali's son's Avatar
81cali's son
I remember that happening to my Dad's 81. What we did was leave the bleeders open over night then plug them and it worked. just make sure if you do this leave something under the bleeder to catch the fluid that will leak out. We didn't and kinda made a mess...
Old Jun 28, 2008 | 06:24 AM
SH-60B's Avatar
SH-60B
Start with the one furthest away from the master and work towards it. rr, lr, rf, lf.
Old Jun 30, 2008 | 12:58 AM
feb18blacksunday
Thanks guys had to work all weekend and I'll start on Monday pm.
Old Jun 30, 2008 | 01:15 AM
Retro78's Avatar
Retro78
You may be dealing with two problems. But for sure your hoses are bad...they retain pressure and degrade from the inside. As per the above posts.... start fresh with all new hoses and re-bleed then see what you have. You could be correct about the vacume assist, but do the hoses first.
Old Jun 30, 2008 | 01:23 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Another quick way to check for a partially blocked/collasped rubber hose is to have someone apply the brake while you try and turn the wheel. Have them release the brake and the wheel should immediately start turning. If there is a delay in the wheel starting to move or it turns hard and then eases up, you likely have a collapsed hose.
As far as you locking issue, also make sure you have 1/16 - 1/8" end play between the pedal and the MC push rod. And lastly check the brake switch itself. I recently had a bad switch which was keeping the pedal from fully returning when released. FWIW.
Good Luck!
To brake
