How to set engine / transmission angle? (LS1 more specifically)
Old Jun 25, 2008 | 10:01 AM
C3KILLER's Avatar
C3KILLER
Default How to set engine / transmission angle? (LS1 more specifically)
I am to the point of bolting up my engine and tranny (LS1 / T56) and am curious as to how to measure the engine / transmission angle. I need to mount the transmission to that center crossmember, and am going to try and do so with some sort of fabricated mount, but I want to make sure everything is going to be aligned properly. Any ideas guys?
Old Jun 25, 2008 | 10:36 AM
72LS1Vette's Avatar
72LS1Vette
This is pretty un-scientific but there aren't many LS1/T56 conversions using the stock frame, at least not that I could find. The driveline angle is more severe side-to-side due to the shorter driveshaft, so I tried to get the front u-joint to be square in the vertical axis. I made my mount adjustable so that I can change the angle if the trans hits the tunnel once the body is back on. After I can test-drive the car I'll probably have the mount welded into place. Here are some pics of my solution. Don't laugh at my fabricating skills or I'll delete the pics.
Rick B.
Mount sitting on top of x-member:
Trans lowered to make u-joint square vertically:
Adjustable mount - uses stock holes on top and bottom of x-member:
Old Jun 25, 2008 | 10:55 AM
C3KILLER's Avatar
C3KILLER
I think I remember reading somewhere that the tranny needs to have a rubber mount for 'movement' I am running solid motor mounts, do I need to use the stock rubber tranny mount and make that work? And the adjustable idea is great. That way I can make sure it is perfect. What driveshaft are you using?
Old Jun 25, 2008 | 11:42 AM
72LS1Vette's Avatar
72LS1Vette
Don't know the answer to the mount question. I'm using standard rubber engine mounts and a poly trans mount. The driveshaft I'm using came from a car that had a TH400 trans in it. I'll see if I can find the measurements and post them.
Rick B.
Last edited by 72LS1Vette; Jun 25, 2008 at 03:52 PM. Reason: corrected trans model
Old Jun 25, 2008 | 11:55 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Straight is bad, angle is good. Your tunnel will dictate the distance. There is a bumper on top of the trans that will only let it go up so high.
To How to set engine / transmission angle? (LS1 more specifically)
