78 build thread..
Old Jun 25, 2008 | 02:43 PM
Flossy's Avatar
Flossy
Cruising
Default 78 build thread..
Long story short, I am Shawn, and my buddy with this car and user name I am posting under is Jarrett.
Car is a 78 corvette..threw a rod and made a strainer out of the oil pan. Through a friend of mine he gets my number and we start coming up with some idea's..it went from just a simple stock engine replacement but spun out of control...
we looked over some options and came up with the following
-Derebery performance 350 ci 400 HP 430 TQ..dyno numbers spit out 447 lbs at 3700 rpm and 417hp @ 5700 rpm, its tuned and purchased as a turn key http://www.dpmpower.us/smallblock.php...should melt some tires compared to the stock tired 350
-Transmission selected is a stage two bowtie over drive 700r4, 2200 stall. complete with holley tv cable, new throttle, shift lever brackets and hard parts..
To put the trans mount in the right place, a bowtie overdrives cross member will be put in place of the old unit. http://www.bowtieoverdrives.com/cata...php?ITEMID=112
next on the parts list is a new aluminum radiator with built in electric fan and t-stat contoler.
other things going on, rebuild of rear suspension, rebuild of rear drive line, gears changed to 3.73, body mounts, clean up and detail of engine bay. frame/firewall etc.. tranny temp guage/ tach, hoses, lines and all the little stuff oh..and side pipes
should be a fun project and Ill post pics as we go. Any feedback or info is more than welcome.
Old Jun 27, 2008 | 12:30 AM
Flossy's Avatar
Flossy
Cruising
Old Jun 27, 2008 | 12:38 AM
Flossy's Avatar
Flossy
Cruising
Having 2 issues..
1. is the water pump is hitting the timing chain cover bolts, seems to be about 1/4 inch of an issue..The pump is the vett specific one as I had read that using the wrong one will cause alignment issues with the pulleys or vett accessory brackets.
so since the block is a vortec block I assume we are now looking at possibly having to purchase some new brackets and pulleys?
2. is the hood clearance, the crate motor comes with a high rise intake as well as a spacer for the carb. We tried it with out the spacer and still could not fit the slimmest of the three air cleaners I had to try on it. We then removed the installation/fire blanket from the hood and it just barely fits but is touching. Other air cleaners you guys know of that will work? I am pretty sure we can find on that will.
oh the fun..
Old Jun 27, 2008 | 07:11 AM
SH-60B's Avatar
SH-60B
Can you get a drop-base air cleaner over that carb? That one doesn't look drop-base. Nice build up BTW.
Old Jun 27, 2008 | 01:39 PM
justaguy10825's Avatar
justaguy10825
I am not completely sure but it sounds like the water pump you have is a "Short" water pump but the engine/timing cover is set up for the "Long" water pump....
The air cleaner issue should go away if you get the drop base... I had the same issue on my 78
Old Jun 27, 2008 | 01:41 PM
justaguy10825
This is air cleaner fits under the stock hood just fine...
http://www.vettemod.com/forum/imageh...c80d84f6ac.jpg
Old Jun 27, 2008 | 08:16 PM
Flossy's Avatar
Flossy
Cruising
Thanks for the info on the air cleaner.
as for the long waterpump, we'll try that and see what issues the brackets and pulleys give us!
To 78 build thread..
