Caliper rebuild
Old Apr 24, 2008 | 08:31 AM
Vetdremz's Avatar
Vetdremz
Default Caliper rebuild
Has anyone re-built their own calipers? My car has been sitting (worst thing possible for seals) and the seals began to leak. Two of them were frozen up. The sleeves are not stainless but honed to be in near perfect condition. The worst problem I am having is finding decent rebuild kits for these.
Has anyone rebuild theirs and been happy with the rebuild kits they purchased ? If yes, where did you get them?
thanks, STEVE
Old Apr 24, 2008 | 08:42 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Yes, you can easily rebuild them yourself. Most Vette vendors sell the kits. Take a look at this: http://www.corvettefever.com/howto/25438/index.html
Old Apr 24, 2008 | 08:47 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I know I'm great at spending other people's money, but it really makes sense to just bite the bullet and buy 4 stainless steel sleeved calipers and be done with it. There are some pretty reasonably priced deals out there and it's a simple bolt on and bleed.
Old Apr 24, 2008 | 08:49 AM
Vetdremz's Avatar
Vetdremz
THANKS!!
Old Apr 24, 2008 | 08:51 AM
Vetdremz's Avatar
Vetdremz
My calipers are in PERFECT condition for rebuilding. I just need to find a good seal kit.
Old Apr 24, 2008 | 09:12 AM
Jud Chapin's Avatar
Jud Chapin
Just be sure they are stainless sleeved. If they are not, they're not worth rebuilding as they won't last. Good luck.
SharkAttack's Avatar
SharkAttack
If they're honed well, you should consider rebuilding them with an o-ring seal kit. I've successfully rebuilt many C-3 calipers but they eventually leak again if the car sits. The most permanent resolution would probably be replacing the calipers with stainless steel sleeved calipers that use o-ring seals.
Jud Chapin's Avatar
Jud Chapin
THANKS!!
You're very welcome!
Old Apr 24, 2008 | 09:53 AM
TopGunn's Avatar
TopGunn
I know this is not going to be a popular opinion but I don't agree with this. As long as your calipers arent rusted in the bore there's nothing wrong with rebuilding calipers that aren't sleeved.
It's a pretty easy thing to rebuild them as stated above and parts are readily available, I've done mine in the past.
Old Apr 24, 2008 | 10:34 AM
spookytooth's Avatar
spookytooth
I agree with TopGunn, most of these need to get sleeved because the bore is pitted. If your bore is not pitted and within spec (you need to measure with a bore gauge) you can just rebuild the caliper. I would guess that you could take them apart, clean them and reassemble and it would work like new. The problem with the OE design is the seals work with pressure, take off the pressure and they may leak. If you were to get in your car once a week and press the brake pedal I doubt it would have ever leaked.
But to avoid that you have two options, buy sleeved calipers (as there are good deals out there) or fix yours. If you buy new, make sure they are fitted with o-rings. If you re-do yours you will need to replace the pistons with the o-ring style and use silicone brake fluid.
I think I got my parts from Vette Brakes & Products.
Good Luck
Old Apr 24, 2008 | 11:05 AM
Brooklinite's Avatar
Brooklinite
Good Luck
I just rebuilt one for the first time with a seal kit from Corvette Central and the above-mentioned article from Corvette Fever. It was easier than I thought it would be.
I've seen a lot of posts saying to replace Dot 3 fluid with Silicone but I'm not sure how that works as I am under the impression that all dot 3 needs to be removed before you can introduce the silicone fluid to the system. Is this true? If so, how do you get all of the old fluid out?
Old Apr 24, 2008 | 11:56 AM
Green76's Avatar
Green76
Steve,
You can go out and buy a rebuild kit from any local auto parts store in your area.
Old Apr 24, 2008 | 12:05 PM
7T1vette's Avatar
7T1vette
Yes. If you want to use silicone brake fluid, you have to purge and clear all of the 'regular' stuff before you introduce the silicone.
Old Apr 24, 2008 | 12:25 PM
Vetdremz's Avatar
Vetdremz
Where did you get your parts?
Were you happy with them?
Old Apr 24, 2008 | 12:32 PM
Scott Marzahl's Avatar
Scott Marzahl
You can buy high quality O ring and standard seal kits from Vette Brakes or Lonestar Caliper. Their rubber tends to be a little thicker than the seals from Autozone etc.
Old Apr 24, 2008 | 12:37 PM
redvetracr's Avatar
redvetracr
I`ve had less than good luck with seals from Autozone but NAPA, Lonestar or VB&P all have quality seals.
redvetracr
Old Apr 24, 2008 | 01:13 PM
spookytooth
right, rebuild MC and replace flexible lines (upgrade to braided?)
and flush well.
The problem with Dot 3 and non sleeved calipers is that it attracks moisture and causes pitting corrosion. So if you do not want to clean the system and replace elastomers, go with the stainless sleeved.
Also, an industrial rubber supply company is a good place to get high quality o-rings. They should be able to help you with sizes and compounds. Not all rubber is the same. There are differant compounds and quality of blend. Some of the imports use a higher percent of fillers with will affect compression set and chemical resistance.
To Caliper rebuild
Old Apr 24, 2008 | 01:30 PM
dennis's Avatar
dennis
Orings and aluminum piston swap and your go to go for a looooong time. When I bought mine from the maker of the piston(ZTI), about 12 years ago, he said,"DO NOT SLEEVE A GOOD BORE". Not a bit of trouble since
Old Apr 24, 2008 | 01:32 PM
Jud Chapin's Avatar
Jud Chapin
As they say, we learn something new every day!
Old Apr 24, 2008 | 02:52 PM
TopGunn's Avatar
TopGunn
http://www.vbandp.com/
Sounds like dennis has a good source also. I did run across a rebuilding document that someone did that was pretty good, can't find it at the moment but I'll locate it and post the link.
Edit: This is a process for installing 'O' rings but it gives a pretty good step by step on how to take things apart and how to put them together again.
http://temp.corvetteforum.net/c3/joe...ructions.shtml
