New Best ET...
It was hot and humid, but the new 427 combo posted a 11.07 best time. The first run was 11.11 but I ran up against the rev limiter at around 6800 rpm....I tried shifting at 6500 but the engine revved too quickly upward from there and sputtered.
( Question- how accurate is the factory tach?....the needle bounced around near 6500, so I think I was possibly higher than indicated.)
The next run I short shifted at 6000 1st-to-2nd, and 5500 for 2nd to 3rd gear (auto trans). Off the line, I footbraked to 2000 rpm and let the converter flash.....instant hook-up!
It was apparent that it would be much later before it would cool off and with hundreds of others waiting, too, I called it a day and will make
my assault on the "10's" at another time. In the meantime, I'll adjust the rev limiter and maybe buy a more accurate tach.
Time slip info...1st run
2nd run....better ET, though lower trap speed
Those 60' times have to come down. With your kind of power, you should be in the high 1.40's - mid 1.50's...
Just noticed the 5.005 60' time of your opponent.. Did he race with his bicycle??
The factory tach cable will bounce all over the place and is not very accurate. I replaced mine with an electronic factory looking tach and it is much smoother and reliable. I also use a shift light so I don't even look at the tach anymore. Just shift when the lights comes on.
You could probably get it to 60' a little better but......I doubt you ever se 1.40s with stock suspension, full weight etc...... I could see some 1.50s-1.55s maybe but.....
So 630 crank HP is getting 125mph through the traps through TH400...... That gives me an idea of where I need to be.
Tires are MT ET Street Radials...
http://store.summitracing.com/largei...=mtt-3752r.jpg
Short footage, so don't blink....
Glad to see the track made it past the 50-year mark!
Thanks for sharing, and congrats on your new best-ET!
Congratulations again!
JIM
JIM
What a great car....
