torque converter
Old Jun 27, 2008 | 06:24 PM
tgcattle's Avatar
tgcattle
Default torque converter
Anyone know if a torque converter makes a rattlling noise if it's going bad?
Old Jun 27, 2008 | 06:35 PM
c3corvettes's Avatar
c3corvettes
Yes it does. It happened to my '80 a few years ago.
Old Jun 30, 2008 | 06:53 PM
tgcattle's Avatar
tgcattle
thanks
Old Jul 1, 2008 | 03:46 PM
charger212's Avatar
charger212
Check your flex plate also, it can make noise if it is cracked.
Rob
Old Jul 1, 2008 | 04:21 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Rob
I had a 68 Chevelle that started rattling as you describe ... it was a cracked flexplate.
Old Jul 1, 2008 | 06:12 PM
Jim_Harrison's Avatar
Jim_Harrison
Mine did, the bolts were loose.
Old Jul 2, 2008 | 01:50 PM
tgcattle's Avatar
tgcattle
It only does it at idle in nuetral. If I am stopped and it's in gear it does not make a noise. Then if you drive at speed it makes a noise. I checked the bolts
Old Jul 2, 2008 | 02:34 PM
7T1vette's Avatar
7T1vette
Sounds more like the tranny itself, since it doesn't make noise until you are moving. The flex plate and converter are turning when idling.
To torque converter
