Timing Again
Old Jun 28, 2008 | 01:35 AM
foooz's Avatar
foooz
Default Timing Again
Just removed my timing chain cover and found a couple of interesting things. The mark on the crank gear is verticle however the mark on the cam gear is at about 5:30. I would expect them to be lined up??? The chain itself is very loose on the passenger side of the engine (left when facing the front of the engine) and very tight on the driver side. Does it appear I have jumped a tooth? The car was running and seemed to be running well when I pulled the engine. I am planning to put the crank and cam gears aligned vertically. If this is not right someone please speak up.
scott
Old Jun 28, 2008 | 02:42 AM
Scott Marzahl's Avatar
Scott Marzahl
Normal straight up installation is with both dots at 12 o'clock.
Old Jun 28, 2008 | 03:01 AM
mopkop's Avatar
mopkop
Default timing
Crank gear dot at 12 o clock and cam gear dot at 6 o clock facing each other with # 1 at tdc
J Smit
Old Jun 28, 2008 | 07:12 AM
mikep3's Avatar
mikep3
Default 12 O'Clock or Dot's Together
I just completed a head and cam change.
When I removed the timing cover ( had #1 TDC and Distributor pointing to #1 Plug Wire) both dot's where at 12 O'Clock. I reinstalled the new cam with the dot's at 12. The sheet that came with the Crane Cam was not clear on this issue showing togheter and at 12.
I took 3 hours of rotating the cam and comparing the lifters and pistons to varify the power stroke on #1 so I could install the distributor.
Old Jun 28, 2008 | 08:28 AM
Durango_Boy's Avatar
Durango_Boy
It doesn't matter if the dots are both straight up or nose to nose. The key is that they are both perfectly vertical. Get the dots lined up, make sure #1 is on compression stroke, and stab in the distributor so the rotor is lined up with the #1 plug wire point.
Old Jun 28, 2008 | 12:44 PM
Scott Marzahl
Beg to differ, if you line them up dot to dot, you better rotate the crank 360 degrees because with the crank dot at 12 o'clock and the cam dot at 6 o'clock, you're at #6 TDC on the compression stroke, not #1 TDC on the compression stroke.
Old Jun 28, 2008 | 01:27 PM
Durango_Boy
Oh I totally agree, I'm just saying it doesn't matter initially where those dots are so long as they are both straight up and the engine it turned so #1 is top dead center. Usually after the timing is on, you still have to turn the engine a few times anyway based on other components being added.
Old Jun 28, 2008 | 01:47 PM
Scott Marzahl
We just want to try to make this as easy as possible for an assumed rookie, now go have a Corona for me Matt.
Old Jun 28, 2008 | 01:49 PM
Durango_Boy
Old Jul 4, 2008 | 12:58 PM
foooz's Avatar
foooz
Okay now I am confused but think I am okay. I replaced the gears as they came off. I had a few too many Coronas when I wrote the original message. When I turned the crank the two dots lined up. Cam as 6 and crank at 12 so I installed the new gears and chain the same way. Later I turned the engine over by hand with thumb over number 1 plug hole. I felt the air pushing out and moved until the timing mark on the harmonic balancer was at about 0 degrees. I then installed the distributor with the vacuum advance (when looking from front of engine) at about 8 oclock and the rotor pointing to about 7 oclock.
How bad did I goof this up?
scott
Old Jul 4, 2008 | 01:48 PM
Lynx_6's Avatar
Lynx_6
6th Gear
Sounds close: normally with HEI the #1 plug terminal sits about 5:30, when viewed from the front, as should the rotor, with #1 cylinder on compression stroke.
Old Jul 4, 2008 | 02:08 PM
Durango_Boy
scott
That's very close. The actual position or the rotor is irrelevant if you're that close because you can turn the body of the distributor, where the rotor stays put, until the rotor points to the #1 plug terminal.
Basically, if you got the dots lined straight up, have the balancer at 0 mark, and have the rotor pointing to #1 plug wire, and the firing order correct going clockwise, then it should fire right up.
Note - When I say point the rotor to #1, I will add that the metal part of the rotor should be just in front of the contact...as in before it gets to the contact, almost touching. That would be advances slightly.
To Timing Again
