timming marks
Old Jul 4, 2008 | 07:03 AM
glo's Avatar
glo
Default timming marks
Should the timming marks be at 12oclock on crank and cam on 6
or both on 12.Getting different opinions on this.
Old Jul 4, 2008 | 08:16 AM
Alan 71's Avatar
Alan 71
The camshaft timing mark should be at 6 o'clock and the crankshaft timing mark at 12 o'clock.
Regards,
Alan
Old Jul 4, 2008 | 08:26 AM
...Roger...'s Avatar
...Roger...
Either one will work-crankshaft at 12 and cam at 12 or 6.
I prefer Alans 12 and 6.
Old Jul 4, 2008 | 09:35 AM
72-LT1's Avatar
72-LT1
When I did mine I made sure everything was at TDC before I took everthing apart. That put them at 12 and 12.
When you take everthing apart, if nothing has slipped they will only go on one way anyways.
Old Jul 4, 2008 | 09:41 AM
...Roger...
Was that TDC firing on #1 or TDC exhausting on #1 ?
Old Jul 4, 2008 | 09:53 AM
stingr69's Avatar
stingr69
12 and 12 is #1 TDC Firing Position.
12 on the crank and 6 on the cam is #6 TDC Firing Position.
Either way #1 and #6 will both be at TDC at the same time. The camshaft position dictates where the distributor rotor needs to point when you drop the distributor in.
-Mark.
Old Jul 4, 2008 | 09:55 AM
Durango_Boy's Avatar
Durango_Boy
I prefer 12 and 6 as well...seems more dead on when lining them up so you don't accidentally get a tooth off.
Either will work, but the builder has to be aware that once the engine is built he must rotate the engine to ensure that piston #1 is at TDC with both valves closed ready for combustion.
That goes for both, and might seem more confusing than it is. It's easier once you remember that the crank spins twice for every cam rotation.
Old Jul 4, 2008 | 10:03 AM
...Roger...
-Mark.
Thanks-couldnt remember if 12 and 12 was #1 fire or exh.- probably cause I dont really use that bit of info for much anyway except for discussions about crankshaft to camshaft relation.
Old Jul 4, 2008 | 10:12 AM
...Roger...
Basics-Very very important-makes things much easier to understand.I see some of the guys here build some really wild stuff and get into trouble because they dont understand the basics.(no disrespect meant)One of those basics is that 2-1 ratio of the crank and cam-it can be confusing but well worth taking the time to understand.Hope everyone has a great 4th of July-today was my fathers birthday.
Old Jul 4, 2008 | 02:28 PM
glo's Avatar
glo
I got it 6 &12, turn over drop dist. in pointing at # 1
To timming marks
