Auto won't shift to 3rd
Old Jun 30, 2008 | 07:57 PM
cduemig's Avatar
cduemig
Default Auto won't shift to 3rd
My TH-400 trans always shifted a little late into third, you'd have to go heavy on the pedal then let off and it'd shift, or just late. I put in a new engine where the trans sat for over a year then put behind the new stroker. I hadn't run it more than 100 miles, but it was shifting the way it always did when the modulator popped out from me putting the wrong bracket in to hold it. It dumped a lot of fluid and I coasted right in front of my friend's house. I put in a new adjustable modulator, refilled the fluid and now it won't shift into third. I was in second when it happened. It also feels slightly less positive on the transition from park to 1st and reverse. I took it to a trans shop and they said they want to do a rebuild, but they really don't seem like they know what they're talking about so I want another opinion before I drop the trans (again). Perhaps installing a shift kit might help, or if it's a pressure problem I might need to replace the pump... Any suggestions?
Old Jul 1, 2008 | 02:28 PM
TimAT's Avatar
TimAT
Did the modulator come all the way out? As in hanging on the hose? There's a valve behind it and it could have blown it out and it's lost. It does have a correct way to install it too- the lands are different from one end to the other..
Old Jul 1, 2008 | 07:55 PM
cduemig's Avatar
cduemig
Yes it came all the way out. I didn't know there was a valve that could come out. I'll check it out. It seems to shift fine in first and second, would that happen with the valve out?
Old Jul 1, 2008 | 08:14 PM
dannyman's Avatar
dannyman
Linkage travel is OK, right?
Old Jul 1, 2008 | 10:35 PM
cduemig's Avatar
cduemig
I'll check the linkage too thanks...
Old Jul 3, 2008 | 04:07 PM
cduemig's Avatar
cduemig
Thanks TimAT!! The valve was missing so thanks to a generous GMC Vandura I no longer have a powerglide! If you're ever in the Norfolk area, let me know, I owe you a beer
To Auto won't shift to 3rd
