I am in the market for a new camshaft for my 77 l48. I was told by a speed shop that my limits for a cam without changing pistons and what not was 268 adv. duration. I looked this up and it was an exhaust lift of .504, and i thought i remembered hearing someone say that the max lift for stock springs was .5
like Matt said, higher lift cams / more agressive cams will require higher strength springs both open and seat pressure...your L-48 heads have press in studs which can be an issue with higher spring loads.
In any case, you will want to match a set of springs to the cam you purchase, the cam card will tell you the seat pressure/open pressures the cam requires.
i already have long tube headers with single chamber flowmasters, no cats. plan on getting intake and carb tuned by lars.
The heads are the biggest hold on how much air you can get in and out of that engine. Even with the exhaust, intake, and cam, you'll be limited.
If you're already buying an intake, plan for a set of cheap used heads that flow better, and will really make use of the rest of the upgrades.
I'm referring to Vortec heads, found in salvage yards all over for around $70 - $100 each. They come from trucks and vans with 5.7L engines from '96 - '00. They can be bolted on with little to no machine work depending on cam. They do require a specific intake, but it seems as though you are already planning to get one of those.
What would cause me to have to have machine work done?
An overly-aggressive cam?
Originally Posted by Matt Gruber
CC HE 268H is .454
springs needed with more aggressive lift cams
Depending on how aggressive the cam is the spring pads may need machining to accept higher lift springs and with higher pressures you'll want screw in studs. On top of that, if you won't be using self aligning rockers you'll want the stud bosses machined down for guide plates.
Like I said though, if your can choice doesn't exceed .470" lift you won't need any machine work...assuming the guides and seals are in good shape.
DB - I've corrected you several times on this but it doesn't seem to sink in. From my own experience, for lift beyond .470 with Vortec heads, the valve guide bosses need to be cut to lower their height to allow higher lift. There is no need for spring pad machining.
There seems to be some confusion about this.
The underside of the retainers will hit the tops of the valve guide bosses with too much lift on an unmodified Vortec head. The fix is to cut the top of the guide down a bit for clearance.
Old school production heads would frequently be modified for larger diameter spring pockets as part of a head upgrade. This was done to allow larger diameter springs. The larger diameters were needed to avoid coil bind at higher lifts and still control the valvetrain at high RPM.
Both issues involve machining the heads but for 2 totaly different operations.
That's what I meant I just keep saying spring pads instead of guide bosses. I knew what I meant but failed to say it properly.
