New Guy
Old Jul 2, 2008 | 12:33 PM
Kevin68's Avatar
Kevin68
Default New Guy
I've been reading this site for a few months now and although I was just lurking, I appreciate the information available. I bought a 68 convertible 3 months ago and have been getting to know my car and work out the kinks. Anyway, like many of you probably, I registered because I had a problem that stumped me and needed some more experienced help. But the correct solution hit me 3:30 am Tuesday morning.
I thought that I should participate in the discussions when I have something constructive to add in exchange for what I've learned and have yet to learn.
Kevin
Old Jul 2, 2008 | 01:08 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Welcome to the Forum!
Old Jul 2, 2008 | 01:18 PM
Durango_Boy's Avatar
Durango_Boy
Welcome. We're a great community of guys that all share a passion for these cars and it's a great place to exchange information even when you're not seeking help with something specific to your own car.
Old Jul 2, 2008 | 02:07 PM
1Fordman's Avatar
1Fordman
Welcome Kevin, I have a 68 bb ragtop that came home in boxes last September and right now the completion meter is at the 70-75% mark. You're in good company, a wealth of knowledge is available here that these great C-3 owners are more than willing to share.
Old Jul 2, 2008 | 02:10 PM
Iskenderian's Avatar
Iskenderian
Kevin
What was the problem? and Welcome!
-Bob
Old Jul 2, 2008 | 08:09 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
Welcome to the 68 club
Old Jul 2, 2008 | 09:28 PM
namttip's Avatar
namttip
I am fairly new, too. I joined for the same reasons as you. Like you, I recieved a friendly welcome, so I should extend the same to you. Welcome to the club.
I also have a '68 convertible.
Old Jul 2, 2008 | 09:47 PM
Kevin68's Avatar
Kevin68
The problem was errartically high/normal voltage on the ammetrer, temperature spikes, (70*+ swings in temp in 10 or less seconds) and brightening/dimming lights. All indicators of a bad regulator, which I changed. The one that was in looked brand new, but replaced it anyway,...no change. So I started thinking along the lines of a bad ground and it didn't occur to me (until 3:30 am) when I replaced the old regulator exactly as the old one was that the wheel well is fiberglass...I'm used to working on metal cars and grounding isn't as big of an issue....the learning curve is steep. Added a ground wire from the frame of the regulator to the car frame, problem solved. Also, the two accessories that were grounded to the regulator frame now work too, who'd a thunk? The car has a new wiring harness, so I'm afraid of what I'll find from the previous owner's mechanic. He jacked him for $700 trying to fix a blinker problem (and never did) I fixed for $2 (apparently unaware that the directional signal switch was not on the fuse panel...and this was a Chevy dealer). At least I got a nice lagre laminated wiring diagram wtih the car.... I know, a bad sign
Thanks to those that responded, I look forward to participating.
Old Jul 2, 2008 | 09:52 PM
Kevin68's Avatar
Kevin68
Oh, and can anybody tell me why the picture in my profile doesn't show up?
Old Jul 2, 2008 | 10:15 PM
namttip's Avatar
namttip
Make sure your picture file size and dimensions meet the requirements. I think it shows the requirements where you attach the picture.
Old Jul 2, 2008 | 10:29 PM
blckslvr79's Avatar
blckslvr79
3:30 am "awakenings" are always when the hardest issues are solved!
Usually after 10+ hours of throwing wrenches!
Welcome!
Old Jul 2, 2008 | 10:32 PM
Kevin68's Avatar
Kevin68
Testin picture. I cheated on the dimensions, but no the file size
Old Jul 2, 2008 | 11:22 PM
Kevin68's Avatar
Kevin68
Last try...for now. Pic is way smaller than the pixel dimensions and fils size.
Old Jul 3, 2008 | 09:16 AM
Durango_Boy
Find an image you want, save it to your desktop at 100 by 100, and upload it. Make sure you click 'save' after it's uploaded and you're done.
Old Jul 3, 2008 | 10:45 AM
Kevin68's Avatar
Kevin68
Default Thx DB
My file is 124 x 86, or something like that and only 17KB. When I view my profile the image is there. But I also got a message "File upload failed."
Will somebody view my profile and let me know if and image of my red 68 vert is there?
BTW, I did save your (DB) instructions on how to imbed images in a message.
I'm at work and don't have photoshop to resize, but will try it later.
Geez, I can fix a car but this rectangle with all the buttons with letters and numbers in front if me is confusing
Old Jul 3, 2008 | 10:52 AM
Durango_Boy
Yeah you have a profile picture but I'm confused as to what you were doing. I thought you were trying to upload an avatar, which is the image to the left of all your posts, under your name. That's the one that has to be 100 x 100. The profile picture, which you uploaded, can be a bit larger and I think it auto scales it in case you upload a large image.
You're on the right track, just keep playing with it.
Old Jul 3, 2008 | 11:53 AM
redwingvette's Avatar
redwingvette
Make sure you check the "show your signature" box just below where you type in your message.
To New Guy
Old Jul 3, 2008 | 12:47 PM
Kevin68's Avatar
Kevin68
Default OK, it's official, I'm a doofus
I obviously don't have any experience with on-line forums. I didn't know what an avatar is? I'm learning all sorts of things.
Old Jul 3, 2008 | 01:48 PM
fauxrs2's Avatar
fauxrs2
<<<<<<< that is my avatar
Welcome to the Forums
vvvvvvvv that is my signature
Old Jul 3, 2008 | 04:41 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Welcome fellow 68 owner
