Clutch Fork Experts: Step In
I have an AIM, Corvette Shop Manual, Chilton's manual, Hayes Manual and 69 Chasis manual and can't find how to install the fork to the ball stud. The only thing one manual says is "there is a difference between the L-48 and L-82 ball stud and the correct stud should be used." There is no picture comparing the studs, or illustrating any difference in the spring configeration.
My spring will not mount on the ball stud I have. I have tried with the stud all the way in, out and in the middle of the bellhousing adjustment. Unless there is some trick to mounting it to the stud, I have to assume I have the wrong stud. The new spring I have mounted to my fork looks exactly like what is pictured in my manual.
Can anyone help me and set me in the right direction on this issue?
What I would be more concerned with is if you dont have the tranny slid back to properly view the TB is that when you do slide the fork in the fork tip and clip will not set correctly in the throught bearing. That when I pulled you clutch I noticed mine was incorrectand the fork tips and clips grabbed the outter ring of the TB instead of snapping inbetween the bearing and that lip.
Sorry I couldnt be more help
BTW...if anyone needs to replace a fork spring I'd suggest using a machine screw for a rivet. Hammer type solid rivets are scarce as hens teeth, so you will probably need to make your own. After finding a suitable length screw, it will be too large in diameter to fit into the hole in the clutch fork. Put the shank into a hand drill , or drill press chuck and turn the screw. Use a file to reduce the screw head diameter. Once you have done this, secure the screw head in the chuck and use the file to reduce the shank diameter. Check frequently to avoid removing too much from the threads.
After making a proper fit, you need to make a head set to hold your rivet while you pound a head on the other end. To make this, I simply found a solid 1/2" X 8 inch shaft and drilled a dimple on one end. This shaft went into a vise vertically. Next, I took a 3/8th X 3 inch bolt and drilled a dimple on the threaded end. This tool is what I pounded on to mushroom the other end of my rivet. The spring has a preload, so it will need to be held in place with a wide jawed Vise Grip while you get the rivet started. Installing a new spring isn't very difficult, it is making a proper rivet and the tools required that made it difficult. And in my case, getting the spring under the pivot ball without breaking another spring.
I replaced mine about two years ago. Got the spring and solid rivet from Zip. Just $6.50 for both. Rivet was made of VERY hard material and required quite the set/pounding but looks and works great.
I hope this thread helps someone down the road doing a search to solve a similar problem.Product Number:CL-175 Price: $6.50
In Stock - Ships Today!
