the right side tail light is not as bright when u hit the breaks and when u turn on the left blinker the right side running light goes off .thanks everything else works fine
Make sure the bulb in that light is the same as in the others. If the bulb is not your problem, it is likely due to a poor ground (corroded connection) or dirty bulb socket contacts.
With all the above posts. Clean the sockets real good, and run a little fine sand paper over the nubs on the bulbs. You can also put some of that electrical grease (for lack of a better name) on the bulbs before you plug them in. I did it and that was 4 years ago. No more problems. Grounding is the biggest problem with C-3 lights.
