Dyno tuning
Just got a quote for having my carb and ignition "tuned" with a dyno. The guy guarantees more horses and if necessary, he will change the jets in the carb for a leaner burn. The kicker is the price. Does $350 seem reasonable?
thanks
Bill
thanks
Bill
Surely it depends on how much time it takes and how many dyno pulls he needs to do. How good or how bad is the car running? Can you get it close enough on your own?
Although I have never had a car on a dyno I have had my Triumph Speed Triple on a dyno twice; once for most of an afternoon. My Kawa ZRX 1200 has had extensive dyno work; when changing cams mostly. Its been vital and expensive; but worth it. At least to me.
carbster
Oh and I will be putting the vette on a dyno post this round of engine work.
carbster
for about the same monies you can buy a LM-1 wideband AF ratio meter and then do the tuning yourself and constantly monitor your AF ratios from idle, cruise, and full throttle for max power, etc.
btw...you want a richer mixture for more HP at WOT...only a leaner mixture at cruise/idle for fuel economy
I did a dyno tune recently and it was kind of cool but a pain in the a$$....as I feel there is still a lot of room for improvement.
From: San Diego - Deep Within The State of CONFUSION!
I was a service writer for a local dyno shop for a coupla years. Yes that is a fair price. Be sure to ask for BEFORE TUNE and AFTER printout results.
Also make sure you have at least a half tank of fuel before bringing it to them! You would be amazed how many cars run outta gas on the dyno.
